YARR
wiki under construction
YARR - Yet Another RepRap
Description | |
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Introduction
- YARR (Yet Another RepRap) is an open source 3D printer designed and developed by LEDs&Chips Creative Electronics. YARR is based on the CoreXY technique [1]and adds several improvements to other printers.
- Where to buy
- Leds & Chips Assembled - Portugal
Gallery
Technical specifications
Dimensions
- Printer Dimensions: 1250(X) x 1250(Y) x 1250 mm(Z without bowden tupe support) 583 mm(Z with support )
- Print Area Dimensions: 750(X) x 750(Y) x 750 mm(Z)
Mechanical Construction
- OpenBuilds V-Slot aluminium frame
- OpenBuilds Wheels carriages X, Y, Z
- Axial ball bearing pulleys B623ZZ for X, Y
- Flexible aluminium coupling for threaded rods of Z Axis
- 9 point print base levelling system with cushioning
- Quick change system for print base
- Brushless Fans with axial ball bearings.
Print resolution
- Very high: 60 microns
- High 100 microns
- Medium 200 microns
- Low 300 microns
Extruder Mechanics
- -Custom extruder design
- -0.4mm nozzle
- -Heat-sinks with axial fan
- -Part cooling nozzle
Print speed
- -Recommended speed: 50 mm / s
- -Maximum recommended speed: 120 mm / s
Electronics
- Any RepRap electronics conforming to RepRap Interface Standard RIS 1.
- -LCD with rotary encoder and push-button navigation
- -Cold glass base (size:750 x 7500 x 4 mm)
- -Power supply: 220 AC 12 DC 100W
- -Thermistor 100k extruder
- -Heating element: 12V 40W
Software
- -Firmware derivative Marlin
- -Recommended environment: Cura Software
- -Supported Files:. Gcode
- -OS supported:
- Windows XP and above
- Mac OS X and above
- Linux
Communications
- -Standard SD card reader
- -USB Port Type B
Materials
- PLA Filament 1.75-mm
