Wildseyed Simple Hot End
Wildseyed Simple Hot End v2
Release status: Working
Description | Wildseyed Simple Hot End
License | GPL
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | |
External Link |
Design Goals
Design Goals
- Simple construction with readily available tools and materials
- Reliability
- Easy Removal
- Low Cost
Tools Required
- Drill Press
- Drill Bits
- Hack Saw
- Tap and Die Set
- Large Pliers or Vice Grips
- Flat File
- Caliper
- Scissors
- Soldering Iron
- Barrel Crimp Tool
- Small Brush or Cotton Swab
Materials Required
- Aluminum Block
- Brass Coupling
- Copper MIG Type Welder Tip
- Set Screws
- PTFE Rod
- 100k Thermistor
- Dale Power Resistor 5 Ohm 1% 5 Watt
- Kapton Tape
- Emergency Tape
- Heat Sink Compound
- Crimp-on barrel connectors
- Small Alligator clips
- Teflon Insulated Wire
- Plastic Ties
