Wildseyed Simple Hot End
Revision as of 13:35, 18 May 2011 by Wildseyed (talk | contribs)
Wildseyed Simple Hot End v2
Release status: Working
[[image:[WildseyedSimpleHotEndv2ProfileView.JPG|center|190px]]
GPL
Design Goals
  • Simple construction with readily available tools and materials
  • Reliability
  • Easy Removal
  • Low Cost
Tools Required
  • Drill Press
  • Drill Bits
  • Hack Saw
  • Tap and Die Set
  • Large Pliers or Vice Grips
  • Flat File
  • Caliper
  • Scissors
  • Soldering Iron
  • Barrel Crimp Tool
  • Small Brush or Cotton Swab
Materials Required
  • Aluminum Block
  • Brass Coupling
  • Copper MIG Type Welder Tip
  • Set Screws
  • PTFE Rod
  • 100k Thermistor
  • Dale Power Resistor 5 Ohm 1% 5 Watt
  • Kapton Tape
  • Emergency Tape
  • Heat Sink Compound
  • Crimp-on barrel connectors
  • Small Alligator clips
  • Teflon Insulated Wire
  • Plastic Ties
