Wildseyed Simple Hot End
Release status: Working
Description | Wildseyed Simple Hot-End
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Design Goals - Simple contruction with readily available tools and materials - Reliability - Easy Removal - Low Cost
Tools Required - Drill Press - Drill Bits - Hack Saw - Tap and Die Set - Large Pliers or Vice Grips - Flat File - Caliper - Scissors - Soldering Iron - Barrel Crimp Tool - Small Brush or Cotton Swab
Materials Required - Aluminum Block - Brass Coupling - Copper MIG Type Welder Tip - Set Screws - PTFE Rod - 100k Thermistor - Dale Power Resistor 5 Ohm 1% 5 Watt - Kapton Tape - Emergency Tape - Heat Sink Compound - Crimp-on barrel connectors - Small Alligator clips - Teflon Insulated Wire - Plastic Ties
