Wally
Revision as of 06:28, 9 September 2013 by KalleP (talk | contribs) (Created a new page as a place holder for the soon to be announced Wally SCARA printer)
Wally
Release status: experimental
Linear bearing free 5 arm SCARA printer
conceptforge.org
No pictures in Wiki yet as file upload is not working for me. You can check out the following in the forum thread in the meantime.
There is a lot more that needs to be added here but others have more knowledge of this printer, I have merely been an observer in the process. Check licence condition.
Wally is a modern SCARA design printer with a parallelogram constrained build bed elevation. It has no linear bearings and needs no timing belts. It uses a Bowden extruder and hot end and can work with the standard electronics with slicer or firmware changes for the kinematic calculations.
Developed to prototype stage by Nicholas Seward from brainstorming ideas by many on the "Delta robot 3D printers" Google Group in a thread titled "Delta mechanism variant" started by Billy Zelsnack and distilled further by user see3d when moving the development to RepRapForum, with continued brainstorming and prototype testing.
The completed printed part design by Nicholas is due for formal release on 22 September 2013 and he plans to sell beta test kits for people to try out at cost.
Design Goals
  • No linear rails
Specifications
  • Build Volume:
  • Build Area: 150 x 150mm or 200mm circle
  • Build Height: mm
  • Speed: mm/s
  • Realistic Print Speed: mm/s
  • Cost: $
  • Estimated Build Time: hours
  • largest part 175mm
Videos
Bill of Materials
  • 4 x Nema 17 stepper motors. 400 step preferred for XY motors
  • 1 x Polished Basalt print bed
  • 1 x Silicone covered bed heater pad
  • 1 x Azteeg X1 controller
  • 4 x SureStep drivers (1/32 microstepping DVR type)
Firmware
Software
Assembly
Simple assembly with a little fiddling with the string drive.
Homing
RepRapNess
  • >% plastic
  • <% hardware
  • about % wooden bed and glass
  • parts
  • plastic parts
  • unique parts
  • unique printable parts
  • hour replication time at 33mL/hour
  • can print parts for larger than self version
Future Developments
  • Exchangeable print heads
  • Larger build volume
Brainstorming history
Distilled by user see3d.
Details about the concept
  • Built off a rigid back board. The board can have ribs attached to make it more rigid. The material is TBD based on prototype needs.
  • Wally could be designed to fold fairly flat for storage or portability. Think suitcase with a handle on the side. Legs could fold out to make it free standing, or it could be attached to a wall.
  • The design can be scaled. Perhaps a 12" backboard width at the small end. That might give more than a 6" cube build volume. A 15" backboard width might give something on the order of 10" Diameter, or an 8" square, or a 10" x 7" Rectangle -- all with a 10" height. I think this would be a good design center.
  • All axis are driven from stepper motors through a Spectra fishing line drive on preferably smooth pulleys.
  • The two X,Y arms are driven by rotating the elbows. This gives a build area that is limited by an arc from the shoulder with a straight elbow to the hot end.
  • The ratio of the stepper drive to large elbow pulley determines the resolution and torque. 0.025mm or better with a reasonable ratio with a 16-32x microstep.
  • The Z axis is a 4 bar linkage that keeps the bed flat as it is rotated up and down through an arc. Gravity lowers and a stepper winding a string raises it.
  • The build platform moves through an arc as the Z is changed. The X,Y Arms have to compensate for the displacement in the Y axis (perpendicular to the back board).
  • A convenient place for a spool is on the lower back. Filament would be fed up through a Bowden extruder and over the top and down to the hot end.
Other brainstorming ideas
An end stop for both arms and possibly a table levelling Z probe might be able to be designed with just one microswitch located on the effector.
It might be possible to have a hot end tool changer. If the hot end is held with magnets on the effector, the hot end could be parked along the back wall to be picked up as needed. A strong hold magnet at the backboard could be magnetically adjusted to hold or release a tool. They would each have to have their own Bowden extruder. This would allow for multiple extrusion heads that stayed in the same centre of arm rotation, and did not require any reduction in build area.
With a universal holder design, things like a Laser Diode head, a light duty rotary cutter head, a magic marker, or a clay extruder could be accommodated. To offset some of the weight of a heavy tool, a counterbalancing string could be added from above. How practical these things would be would have to be tested in a prototype.
Links
Development Forum for Wally design progress
