Wallace
Release status: experimental
Description | Wallace is a parametric version of the Printrbot design.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Overview
The RepRap Wallace is named after Alfred Russel Wallace, who independently discovered the theory of evolution by natural selection after Darwin, but before he published. It is loosely based on the Printrbot, but is a complete redesign in OpenSCAD to be more robust (without the loose press-fit mountings), but still extremely simple. It is designed for use with 6mm smooth/threaded rods and NEMA14 motors like the ones used in the Huxley design, and LM6UU bearings for linear motion, though its parametric nature means that NEMA17/M8/LM8UU versions will also be possible. STLs can be found on thingverse, the source is on Github, and the latest updates/previews can be found on Whosawhatsis' Google+ page. This design is a work in progress.
The initial build guide is posted here- http://reprap.org/wiki/Wallace_Build_Manual
--MrJohn 01:25, 3 February 2012 (UTC)
Video showing Printf.bot first print on 2011.12.31, driven by R2C2 (recorded on 2011.12.31 by Casainho):
<videoflash>Igdbltngic0</videoflash>
Video recorded on 2011.12.17 by Whosawhatsis:
<videoflash>0QrEmGlZT0w</videoflash>
<videoflash>fq3ihIT_C9s</videoflash>
Parts
In addition to the printed parts, the following parts are required (this is a tentative list, and the parts WILL change before the design is complete):
- 4 high-torque NEMA14 motors. Sources:
- Pololu
- Zapp Automation
- Waterott for 20 oz-in non-dual shaft in Europe
- 1 set of electronics
- 1 extruder
- 3 pairs of 6mm smooth rods (measurements will depend on desired build volume. 350 mm X 320mm X 350mm gives about 200 x 200 x 170mm).
- McMaster-Carr
- Fastenal
- ebay
- These can probably also be found locally.
- 2 pairs of M6 threaded rod (measurements will depend on desired build volume) (+3 more: 1 between z-top-clamps, 2 for optional feet?).
- McMaster-Carr
- Fastenal
- ebay
- 10 M6 nuts -- (8 for threaded X-rod, 2 for Z leadscrews?) (+4 for Z_top_clamp?, +4 for Y-Idler)
- These can be found locally.
- 2 M6 nylock nuts -- (for the leadscrew couplers. You may substitute 2 regular M6 nuts tightened against eachother to lock them in place.)
- 8 M6 washers. (8 for threaded X-rod)
- 11 LM6UU linear bearings. (4 Y-bars/Base, 4 Z-bars/X-ends, 3 X-bars/X-carriage)
- 3 623 bearings. (6 needed for the double-bearing idlers)
- 17 10mm M3 screws -- (8 base motor + Y-bearing clamps, 4 Z-sockets, 2 drive pulleys, 2 Z-connectors, 1 X-belt clamp)
- 7 30mm M3 screw -- (2 Y-idlers, 2 Y-belt mounts, 3 X-motor mount?)
- 2 50mm M3 -- (X idlers + x-bar/z-bearing clamps?)
- Approximately 13 M3 nuts and washers.
- 1 sheet of MDF or other flat material (measurements will depend on desired build volume).
- You can buy this locally and cut to size.
- 2 belts
Printed parts
- 2 bases
- Get it on thingiverse page
- 4 bed mounts
- 2 leadscrew couplers
- 1 X carriage
- 1 X end left
- 1 X end right
- 4 Y bearing retainers
- 1 Y idler
- 3 Idler pulleys (use a 4th pulley to properly align the X belt if your drive pulley diameter does not match)
- 2 drive pulleys
- There are MXL/GT2 pulleys on the thingiverse page, or use XL/T5 pulleys like these ones: (1) (Using 12 teeth in XL or GT2 would about match the idlers.)
Optional:
- 4 Feet
