Wallace
Release status: experimental
Description | Parametric Printrbot Variant is a parametric version of the Printrbot design.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Overview
The Parametric Printrbot Variant needs a better name. It is inspired by the Printrbot, but is a complete redesign in OpenSCAD to be more robust (without the loose press-fit mountings), but still extremely simple. It is being designed for use with 6mm smooth/threaded rods and NEMA14 motors like the ones used in the Huxley design, and LM6UU bearings for linear motion, though its parametric nature means that NEMA17/M8/LM8UU versions will also be possible. STLs can be found on thingverse, the source is on Github, and the latest updates/previews can be found on Whosawhatsis' Google+ page. This design is a work in progress.
Video showing Printf.bot first print on 2011.12.31, driven by R2C2 (recorded on 2011.12.31 by Casainho):
<videoflash>Igdbltngic0</videoflash>
Video recorded on 2011.12.17 by Whosawhatsis:
<videoflash>0QrEmGlZT0w</videoflash>
Parts
In addition to the printed parts, the following parts are required (this is a tentative list, and the parts WILL change before the design is complete):
- 4 high-torque NEMA14 motors. Sources:
- Pololu
- Zapp Automation
- Waterott for 20 oz-in non-dual shaft in Europe
- 3 pairs of 6mm smooth rods (measurements will depend on desired build volume).
- McMaster-Carr
- Fastenal
- ebay
- These can probably also be found locally.
- 2 pairs of M6 threaded rod (measurements will depend on desired build volume).
- McMaster-Carr
- Fastenal
- ebay
- 10 M6 nuts.
- These can be found locally.
- 2 M6 nylock nuts.
- 8 M6 washers.
- 11 LM6UU linear bearings.
- 3 623 bearings. (6 needed for the double-bearing idlers)
- 13 10mm M3 screws.
- 7 30mm M3 screw.
- 2 50mm M3.
- Approximately 13 M3 nuts and washers.
- 1 sheet of MDF or other flat material (measurements will depend on desired build volume).
- You can buy this locally and cut to size.
- 2 belts
- This could be of type "XL timing belt" like here.
Printed parts
- 2 bases
- Get it on thingiverse page
- 4 bed mounts
- 2 leadscrew couplers
- 1 X carriage
- 1 X end left
- 1 X end right
- 4 Y bearing retainers
- 1 Y idler
- 3 Idler pulleys (use a 4th pulley to properly align the X belt if your drive pulley diameter does not match)
- 2 drive pulleys
- There are MXL/GT2 pulleys on the thingiverse page, or use XL/T5 pulleys like these ones: (1)
Optional:
- 4 Feet
