Wade's Geared Extruder
Release status: Working
Description | Geared Nema 17 Extruder
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This work is based on Adrian's Geared Nema 14 extruder design, and includes many concepts lifted from Nophead's extruder research.
This extruder was designed for the RepRap Mendel (but will work on a Darwin or Huxley with adaptors) and is robust, provides a strong force to extrude, is cheap and DIY. It is an alternative to the standard extruder for RepRap Mendel and has the following advantages:
- no need to buy/use expensive metal gears;
- no need to do two precision flats on motor shaft;
- no need to glue the PTFE barrel;
Other advantages over other extruders are:
- extrude/print at high speed;
- good for use with a low torque/cheap Nema 17 motor ; (Needs verification)
- no need to use expensive and complex tools - just one hand drill, a file and a M3 tap;
- no need to make splines on motor shaft;
See this extruder in action (video recorded by Casainho on 2010.08.18): <videoflash type="blip">AYH2oxYC</videoflash> View the high quality original vorbis video file.
View photos of other people's copies of this extruder.
Buy it: If you can't make yours or simple if you do no want, you can always buy one. There are users printing it and selling on Ebay.
Mechanical Construction
Material
Non printed parts...
... for the feeder
- 2 X 608 bearings (Skateboard bearings);
- 1 X M8X50 bolt;
- 1 X M8 nut (Nylock works better, but a pair of nuts will also work);
- 4 X M8 washers;
... for the idler
- 1 X 608 bearing (Skateboard bearing);
- 1 X M8X20 piece of smooth bar, threaded bar or a bolt;
- 4 X M4X45 bolts; - hex head will work best (they won't turn), and longer than 45 mm will be easier to assemble if you can find them.
- 4 X M4 nuts;
- 4 X M4 washers;
- 4 X Springs - 1 mm diameter wire, wound to an OD of 10 mm, with 4 active coils. For a given filament drive force, you'll need about twice the spring force - ie, if you want 100 N of filament drive, your springs need to push with about 50 N each. NOTE: some users have theirs extruders working without this springs, but springs are recommended.
- 16 M4 washers; - optional; 4 washers on each M4X45 idler bolt between the main block and the idler block will limit the idler travel and make reloading filament easier.
... for mounting the hot end
- 2 X M3X35 bolts;
- 4 X M3 washers;
- 2 X M3 nuts;
... for mounting the stepper motor, some motors may require something similar
- 4 X M3X15 bolts;
- 8 X M3 washers;
- 4 X M3 nuts;
... and of course
- 1 X Nema17 StepperMotor
Printed Parts
- 1 X M8_Extruder_Block_3.stl
- 1 X M8_Extruder_Idler_Block_2.stl
- 1 X 11t17p.stl
- 1 X 39t17p.stl
How to build it
I used a hand drill and a file to cut the slot, then hobbed it with an M3 tap mounted in the drill, using bearings mounted in a vise to let the bolt spin - see the next videos. If you're not sure where to cut the pinchwheel slot, test assemble the extruder, making sure you leave room for the motor mount bolt heads under the 39 tooth gear, and mark the M8 bolt where it crosses the filament feed channel.
Filing the shaft: <videoflash type="youtube">2FU0v-3gloo</videoflash>
Using M3 tap: <videoflash type="youtube">Hl4Gf5R4YJg</videoflash>
This is an earlier version with using threaded rod - it's harder to get the hobbing concentric when you cut it into the threads.
You can also use this http://www.thingiverse.com/thing:3780 bolt hobbing tool, or this http://www.thingiverse.com/thing:1802 one.
Using the smooth part of a shoulder bolt works better.
- Note 1 - I prefer to use a Nylock nut on the end of the M8 shaft. Locktite should work as well, or a longer bolt with two nuts.
So far so good! If you add 3 or 4 M4 washers on each bolt before you put the idler block on, it will reduce the idler block travel when loading new filament, making loading new filament much easier.
Here's the test jig:
This extruder hit 16 kg - here's the results: M8 shoulder bolt - 7.0kg, adjusted tension, new springs - 11.0 kg,
Tightened springs, 3 trials:
15.5 kg, 16.5 kg, 15.25 kg
The final failure mode was the stepper running in reverse, as opposed to the filament slipping. That's quite promising.
Hot End
Attach a length of 16 mm OD PTFE using the two M bolts to pin it in place. I pre-drilled the PTFE mounting holes with a 2.3 mm drill, which made for a tight friction fit.
The nozzle can be built however you like; I build them similar to this: http://reprap.org/wiki/Mendel_extruder
I use 8mm od brass rod, with a 4 mm ID melt chamber, insulated nichrome wire and furnace cement to hold it all together.
3D CAD Files
Here's the design files for the latest version:
- extruder body and idler block: File:M8 Extruder 3.zip
- 11 tooth drive gear and 39 tooth M8 hub driven gear: File:M8 Gears.zip
- alternative 11 tooth gear that should be better: File:Nophead gear with setscrew for wade extruder.zip
- (if you do not want to use a vise to support the M8 bolt) use this support for bearings, needed when using M3 tap: File:Pinchwheelwormdrilljig.zip
- Horizontal Wade Mount by tbuser
- Alternative driven gear by GilesBathgate
- You can also get the files from thingiverse although they may not be the most recent.
Finally, here's a spreadsheet to help calculate the proper feedrates: media:feedrates.ods | media:feedrates.xls
An updated version of the spreadsheet to use with Skeinforge, somewhat simplified. I vary the layer thickness, width/thickness and the two speed settings until I get a density near unity for nicely solid solid parts: media:Extruder Calcs 2010.07.13.ods
Stepper Driver
You should be able to use Stepper_Motor_Driver_2.3 to drive this extruder.
Variations on this design
This is the place to add variations and improvements to this design.
Older versions
Here is a link to a previous version of this page that describes an earlier version of this extruder that uses an M4 shaft, and includes more details about pull testing the two versions: "Geard Nema 17 Exteruder Version 0.5"
