Vik's Mendel X & Z interface Bracket
Revision as of 17:53, 18 May 2010 by VikOlliver (talk | contribs) (Useful Pictures)
Release status: unknown
A simplified OpenScad Mendel X/Y interface design
unknown
Overview
This bracket combines all 11 parts for an X axis end piece and Z axis nut holder into just 3 parts requiring no bearings and only 6 screws to assemble. Two M8 nuts are used with internal printed anti-backlash springs to attach the Z drive rods. The limit sensor is glued to the face of the bracket, pointing at the X Carriage.
Pulley Design
The pulleys on the corners are made from stacks of small washers slightly taller than your belt width. These are capped top & bottom with a wider washer. To reduce friction against the M4x40 screw thread, you can insert a piece of 3/16" brass tube (from model shops) so that it fits between the small washers, which now have to be M5. The large washers are still M4. Securing with an M4 nylok nut is recommended as this allows you to leave some play in the washer stack.
Useful Pictures
View of end furthest from X Motor from side.
View of end furthest from X Motor from above.
Work in Progress
See Thingiverse Thing #1825 for instructions and download
