Vertical x for Prusa by North90ty
Revision as of 23:59, 31 October 2011 by North90ty (talk | contribs)
This is a contribution to the Vertical_X_Axis_Standard_Contest. The design is focussed on a quick design that is easily modified and that is easy to print.
About the design
The axis is compatible with the Vertical_X_Axis_Standard. The smooth x-bars are 15mm offset from the z-bars (center to center). The axis is designed to be compatible with the standard Prusa hardware: same belt and same length of bars.
The design files can be found on Thingiverse: Vertical x by North90ty and Micro wade for vertical x
Status
Design is working but likely to change
Vx-motor
Vx-idler
Vx-mWade
Bushing holders
