User talk:RlopezCW
29 de Octubre de 2012.
Después de un fin de semana viendo los magníficos vídeos de obijuan, unas pocas busquedas por ebay y muchas horas de lectura.....
PRIMERA COMPRA: TODA LA ELECTRONICA
En EBAY, algo menos de 150€ con portes incluidos.
1x Complete set of RAMPS 1.4 electronics: - 1x Complete soldered RAMPS 1.4 (More informations about RAMPS 1.4) - 5x A4988 Complete soldered G3D driver with additional CLK trimpot (this is much better than StepStick or Pololu due of selectable off-time) (More informations about GD3 driver) - 1x Mega 2560 (More informations about Mega 2560) - 1x Complete soldered Sdramps extension (More informations about SDRamps) - 1x Cooler Fan - 14 cables (complete wiring cables set):
- 6x 3 PIN cables for endstops
- 3x 2 PIN cables for thermistors
- 5x 4 PIN cables for motors
1x LCD and SD card LCD/SD panel with RAMPS GADGETS3D Shield:
- 1x soldered and assembled panel with 4 rows LCD, SD card connector, ALPS rotary encoder and plastic knob. (More informations about panel)
- 1x soldered RAMPS GADGETS3D shield for easy connect panel into RAMPS 1.4.
- 1x Kingston 2GB SD card.
- 2x 10pin flat cable of 1 meter length.
- 2x 10pin flat cable of 35cm length.
1x RepRap Heatbed MK2a PCB
- 1x MK2a Heatbed PCB with presoldered LED's and resistor (More informations about MK2a)
- 1x NTC EPCOS type 100K thermistor
- 1x Red and Black wires cable which can easily handle over 10A
1x Mechanical Endstops set
- 3x Mechanical Endstop v1.2 (MakerBot style) (More informations about v1.2 Endstops)
- 3x Mechanical Endstop (Prusa style) (More informations about Mechanical Endstops)
SEGUNDA COMPRA: LA FUENTE
En PcComponentes por algo menos de 25€ portes incluidos.
Características de B-Move Fuente Alimentación 600W OEM
Fuente ATX 12V v2.2 Incluye conectores Serial ATA y IDE Voltaje 230 V Ventilador de 120 mm Negro Potencia 600 W Peso 1.04 Kg Conectores: 1 x ATX 20/24 pines 1 x 4 pines CPU 2 x SATA 4 x IDE Certificados: CE, RoHs. · +3.3V - 38A / +5V - 44A / +12V1 - 19A / +12V2 - 19A /-12V - 0.8A / +5VSB - 2.5A Dimensiones: 140 x 150 x 86 mm
30 de Octubre de 2012
TERCERA COMPRA: LOS MOTORES
En eBay por algo menos de 80€ http://cgi.ebay.es/ws/eBayISAPI.dll?ViewItem&item=290772634221
CUARTA COMPRA: RODAMIENTOS LINEALES
Tambien en eBay, los 10 por 4€
QUINTA COMPRA: KAPTON DE 20MM
ebay, 33 metros por 2,5€ se supone que es 280º
SEXTA COMPRA: LAS POLEAS T2.5
En eBay, pero esta vez no es China, es Dinamarca, en total 14€ envío incluido.
SEPTIMA COMPRA: CORREAS, RODAMIENTOS Y 1KG DE ABS
En RepRapWorld, creo que todos conocemos los precios, todo, enviado por Fedex algo menos de 40€
OCTAVA COMPRA: LA FERRETERIA
En las dos ferreterías del pueblo y por menos de 20€ tengo casi toda la tornillería, y las varillas roscada de M8 cortadas, faltan las 3 varillas lisas y las arandelas de M3
NOVENA COMPRA: LAS PIEZAS IMPRIMIBLES
En Clone Wars, a MA_BLACK, por 50€ gastos de envío incluidos (creo que van a ser en dos colores, para vacilar en las juntas)
SOLO FALTA EL HOT END!!!!
