User talk:GreenEllipsis/MMU2S
< User talk:GreenEllipsis
Revision as of 22:03, 24 September 2020 by GreenEllipsis (talk | contribs) (Recovering from MMU2S Errors during Printing)
This content only covers the MMU2S. If you have an earlier version of the MMU, consider upgrading to the MMU2S.
Remedying Printing Problems
Strings on Filament Tips
  • Prusa: increase cooling moves. Decrease nozzle temperature.
  • Klathmon: Too long of strings? Jams going IN to the nozzle? Decrease temps, increase unload speed at start to 120, decrease cooling moves to 1 (multiple cooling moves tends to create long lumpy strings for me). [1]
  • Try 0Calvins settings
LEDS:
* _ _ _ _ Filament 1 load error
_ * _ _ _ Filament 2 load error
_ _ * _ _ Filament 3 load error
_ _ _ * _ Filament 4 load error
_ _ _ _ * Filament 5 load error
  • Determine cause of unload, fix it, press the MIDDLE (retry) button. It should go to * . Press the RIGHT (resume) button.
*  *  *  *  *   Selector or filament(?) motor overcurrent detected
  • Prusa: \[insert video here\]
  • GreenEllipsis: Reduce tension on idler assembly by backing out spring-loaded screws
Wrong filament loaded
  1. Press CHANGE FILAMENT from the i3 menu. The filament will unload.
  2. Press the RIGHT or LEFT buttons on the MMU to move the selector to the correct filament.
  3. Press the MIDDLE button to load the filament.
  4. Press the knob on the i3 to load the filament to the nozzle and resume printing.
MMU2S Modifications
Hot End
Extruder
PTFE Tube Assembly
Generally, modifications involve increasing the inner diameter of the filament path and chamfering various locations.
  • FESTOS or pneumatic couplers
  • PTFE tube diameter
    • replacing the stock PTFE tube with a tube that his the same 4 mm outer diameter, but a 3 mm inner diameter.
Selector
  • Button for MMU2S reset button
  • Captive screw covers for idler tension screws
  • Labels for left, right and middle buttons
Filament Buffer
  • Gravity assist
Firmware
Additional References =
https://help.prusa3d.com/en/article/mmu-loading-failed_2135 https://help.prusa3d.com/en/article/mmu-needs-user-attention_2139
