User talk:Blades Rally Team
Item Description:
You are bidding on 3 Axis TB6560 CNC Stepper Motor Driver Controller Board
Features:
Toshiba TB6560AHQ chip-High power, maximum 3.5A drive current
Professional design, two-stage signal processing, super anti-jamming
1-1/16 microstep setting-Higher accuracy
Adjustable drive current settings for each axis-25%,50%,75%,100% of full current can be set for different stepper motors
Overload, over-current and over-temperature safety - Full protection for your computer and peripheral equipment
On board current switching-Power output can be set according to specific user requirement
Relay spindle interface-Outputs Max. 36V 7.5A for spindle motors or coolant pump (only one device can be powered by this output!)
4 channel inputs interface-Can be used for XYZ limit and emergency stop
Bipolar constant current chopper drive with non-resonant region
Full closed-type optical isolation to protect the user's computer and equipment
Four control inputs (divided into pairs of knives)-Allows setting of limit and emergency stop
Universal architecture-Supports most parallel software MACH3,KCAM4,EMC2 etc
Technical Specification:
Please connect the power supply to the power switch of DC 12-36 V
Voltage Selection:
12-16V DC power supply for Nema 17 stepper motors
16-24V DC power supply for Nema 23 stepper motors
24-36V DC power supply for Nema 34 stepper motors
Driver output compatible with 2 or 4 phase, 4,6 or 8 lead stepper motors, 3A max
Suitable for unipolar or bipolar stepper motors
Voltage regulated spindle speed controlled by parallel interface as function of supply voltage
Auction Includes :(As picture show)
1 x 3 Axis TB6560 Stepper Motor Driver
1 x DB25 parallel cable
5 x Wire connectors
1 x CD software (English Manual & Mach 3)
Item Condition: Brand New!
Would it be possible to use this 3 axis controllers and an extruder controller to drive the Mendel 3D printer?
