User:Wayland
I'm going to use this page as sort of a documentation for my
This is my work-in-progress RepStrap. It'll be big and cheap, as much as I can make it. It probably won't have a great print area for its size (but it's pretty freaking huge), but I don't need to keep this thing on a desk. Y axis runs on aluminum channel, X axis will run on steel rod, and z axis is on threaded rod, with the print platform moving. I'm thinking about using pololu stepper drivers and the sanguino for a motherboard. For the extruder, I might use Adrian's geared extruder, if I can get someone to print the parts for me...
Current Progress: I need a belt for the z-axis and have contacted some friendly people who might make me some pulleys.
To Do List (Not really in order)
(things will be listed as they are foreseen, stricken out when they are completed, and deleted when they are documented and photographed.
- Obtain timing pulleys and belt and finish z-axis
Cut print platform from plexiglass, drill holes, and epoxy nuts onto it. - Build x-axis
- Build belt drive system for x and y axes
- Buy Arduino/Sanguino/Whatever and stepper motor drivers
- Buy thermistor, nichrome wire, pwm, stepper motor for the extruder, hdpe (or whatever) tube for insulation, and first plastic!
Parts
I have basically a scrapyard in my backyard, so a lot of these parts are salvaged. This is a prety cobbled-together thing.
- Aluminum plate, channel, and angle - Salvaged, cut to size with circular saw, drilled with drill press
- 3 Stepper motors - Cheap surplus-store Molon steppers (these guys) - Almost no specifications, I will test them and figure out voltage and current once I get my power supply and drivers. They don't have a great resolution - I'm thinking I will gear them. If they're no good, I can always buy some NEMA 17s.
- 8 skate bearings - Salvaged from an old generic-brand skateboard. These are pretty nice bearings and perfect for what I have in mind. These are just for the y axis - I'm gonna need to find or buy some more for the carriage.
- Threaded rod - Salavaged
Y-Axis
I really liked the self-adjusting bearing arms used in the McWire Cartesian bot, so I made something similar; instead of using a platform, though, I'm using separate (for now) carts that will have the x-axis running between them. Each cart will be driven by a separate belt, both of which attach to the same stepper.
The cart is made of sheet aluminum , as are the bearing arms. The fixed bolts have on them: a spacer, the bearing arm, the bearing, and the nut. The floating bolts are just the arm, bearing and nut. There is a small hole on the inside of each bearing arm; I had planned to use springs like in the McWire, but I only had rubber bands around to test it with, which ended up working fine. If the rubber bands break, though, I'll switch. These carts run on a frame I made from aluminum channel.
Z-Axis
The z-axis runs on four threaded rods arranged vertically in the frame's corners. There are holes in the corners of the x-y frame which the threaded rods go through, and, over the hole, is a washer and a bearing to lessen friction. On the bottom of the legs are guides to keep the threaded rod straight and more bearings. A stepper will be powering one threaded rod, which will then power the rest of them via pulleys and a timing belt. The stepper shaft will be joined to the threaded rod with a short length of neoprene tubing, similar to the mcwire. I will attach it as soon as I assemble the platform and pulleys.
