User:Shark 3D printer
Revision as of 09:55, 19 October 2013 by Shark 3D printer (talk | contribs)
ABOUT/ SHARK
Shark Corporation is a fast growing Lebanese-Based Company that started designing and manufacturing low cost 3D printers which officially started selling in September 2012. Since September 2012, heaps of improvements were made on our product creating a new design which is considered one the best Fused Filament Fabrication 3D printers in the market. Shark 3D printers were ordered to makers and creative people across the world! We make Machines that bring your Idea to Reality! We are deeply committed to deliver these incredible tools into the hands of makers, inventors, and ordinary people around the world assuring the best Accuracy, Velocity, and Smoothness.
ABOUT/ SHARK 3D PRINTER FOUNDER
We are committed to making 3D printing better, faster and simpler. Also, the Shark 3D printers are designed to print larger objects, while the printer only occupies a small space on your desk. We are always updating our product to make the best personal 3D printers. Our Shark 3D is delivered worldwide. Finally, we will make your personal 3D printer a better experience, affordable to anyone!
Zafer Nabil Succari, Engineer
OVERVIEW
PRODUCT DESCRIPTION Shark 3D printers are based on additive layer manufacturing (ALM) methods. Using thermoplastics, a Shark printer heats the material through the extruder (or print head). The extruder then pushes out a very fine plastic thread which is applied layer by layer according to X and Y co-ordinates. The Shark 3D Printer is designed to look awesome and be the most competitive and durable 3D printer on the market. The machine features a high quality of printed product with 1.75 mm extruder and 0.4 mm nozzle, has a large print area and has a high positioning Resolution Up to 100 microns. Build Volume: 22 x 22 x 16.5 cm, 487 cubic inch. SHARK 3D Printer ™ is designed for everyone! Simply load your design and start making, and join the personal manufacturing revolution.
HOW DOES 3D PRINTING WORK? Shark 3D printer is a process of building up layers of either PLA or ABS plastic. The model is formed from the molten plastic using the data from your CAD drawing. The Shark 3d printer opens up a whole new world of creativity. Quick and easy to set up, this affordable 3D printer lets you make the impossible possible.
FEATURES
- Updated with Linear Motion for Best Accuracy, Speed and Velocity - Two hot end Included In box 1.75mm installed and 3.00 mm in the box for your requirement You can install any time - All our nozzle in our hot end is 0.4 mm to get layer resolution up to 100 microns. - Building Volume 22 x 22 x 16.5 cm, 7986 cm3 487 cubic inch - No assembly required. - Updated extruder requires less maintenance - Designed to look great on your desk - Designed for quiet desktop operation - Online support available 6 days a week
SPECIFICATIONS
TEMPERATURE Ambient Operating 15° – 32° C [60° – 90° F] Temperature: Storage Temperature: 0° – 32° C [32° – 90° F]
ELECTRICAL AC Input: 240 V, ~2 amps, 50 – 60 Hz Power Requirements: 24 V DC @ 6.25 amps Connectivity: USB, SD card [included]
MECHANICAL Body: Acrylic 8.00 MM Matt Black Build Platform: Aluminum 4.0 MM XY: Linear Motion for Best Accuracy, Speed and Velocity. Z Bearings: Oil-infused bronze Stepper Motors: 1.8° step angle, Up to 1710 oz-in. (12.1 N • m) holding torque
PRINTING Print Technology: Fused Filament Fabrication Build Volume: 22 x 22 x 16.5 cm Layer Resolution High 100 microns Settings: Depend on user Demand Positioning Precision: XY: 11 microns [0.0004 in]; Z: 2.5 microns [0.0001 in] Filament Diameter: 1.75 mm and 3.0 mm Both u can use just change the Nozzle Diameter: 0.4 mm
SOFTWARE Software Bundle: Pronterface File Types: .stl , .obj. Supports: Windows (XP, 7), Linux (Ubuntu 10.04+), Mac OS X (10.7/10.8)
PHYSICAL DIMENSIONS Without Spool: L 48 x W 45 x H 38 cm. With Spool: L 48 x W 54 x 38 cm
WHAT IN THE BOX
- Shark 3d printer - 1 kg Filament - Both Hot end 3.00 mm additional and 1.75 mm Installed - Kapton tape - Needed Tools - Catalogue - DVD including Software - All what you need to start printing is in Shark 3D Printer box
