User:RobertKuhlmann/RepRap Morgan BOM
This article is the extended version of a material list for the RepRap Morgan.
Please feel free to add missing parts or correct mistakes.
Thanks to Quentin Harley for his permission to do this and for his outstanding Morgan-project.
- 1 Printed parts
- 1.1 01-pvc_pipe_support_a
- 1.2 02-pvc_pipe_support_b
- 1.3 03-z_mount_bottom_8mm
- 1.4 04-z_mount_top_8mm
- 1.5 05-motormount_short
- 1.6 06-motormount_tall
- 1.7 07-drivewheel_rod
- 1.8 08-drivewheel_tube
- 1.9 09-22mm_6805_bearing_adaptor
- 1.10 10-bed_arm_left_8mm
- 1.11 11-bed_arm_right_8mm
- 1.12 12-bed_z_mount_bracket
- 1.13 13-bed_rear_mountclips
- 1.14 15mm pipe holders – To be done
- 1.15 14-bed_front_mountclips.stl
- 1.16 15-hall_endstop_holder
- 1.17 16-leadscrew_shaft_motor_mount
- 1.18 17-Morgan_arm_PSI_a
- 1.19 18-Morgan_arm_PSI_b
- 1.20 19-Morgan_arm_Theta_a
- 1.21 20-Morgan_arm_Theta_b
- 1.22 21-Morgan_toolhead
- 1.23 22-Leadscrew-nut_Alpen8mmSDS
- 1.24 23-extruder_bowden_adaptor
- 1.25 Cap_2
- 1.26 Eckstruder_Big_Gear_Herringbone
- 1.27 Eckstruder_Block_for_Prusa
- 1.28 Eckstruder_Idler_Block_for_Prusa
- 1.29 Eckstruder_Small_Gear_Herrinbone
- 1.30 thumb_knob_M4_extruder
- 1.31 TighteningCone_2
- 2 Hardware
Printed parts
You find the original SCAD-file from Quentin Harley, that does all parts, over here: Original Morgan SCAD-file
I've redrawn some of the parts to ease modifications without scripting.
Socket for PVC-pipe with cable hole
Drawing: 01-pvc_pipe_support_a.pdf
Source (Inventor): 01-pvc_pipe_support_a.ipt
STL-file: 01-pvc_pipe_support_a.stl
Amount needed: 2
Socket for PVC-pipe
Drawing: 02-pvc_pipe_support_b.pdf
Source (Inventor): 02-pvc_pipe_support_b.ipt
STL-file: 02-pvc_pipe_support_b.stl
Amount needed: 2
Z-axis base for 8mm axes
Drawing: 03-z_mount_bottom_8mm.pdf
STL-file: 03-z_mount_bottom_8mm.stl
Source (Inventor): 03-z_mount_bottom_8mm.ipt
Amount needed: 1
04-z_mount_top_8mm
z-axis base for 8mm axes
Drawing: 04-z_mount_top_8mm.pdf
Source (Inventor): 04-z_mount_top_8mm.ipt
STL-File: 04-z_mount_top_8mm.stl
Amount needed: 1
05-motormount_short
Motor mount short
Drawing: 05-motormount_short.pdf
Source (Inventor): 05-motormount_short.ipt
STL-file: 05-motormount_short.stl
Amount needed: 1
06-motormount_tall
Motor mount tall
Drawing: 06-motormount_tall.pdf
Source (Inventor): 06-motormount_tall.ipt
STL-file: 06-motormount_tall.stl
Amount needed: 1
07-drivewheel_rod
Drivewheel for rod
Drawing: 07-drivewheel_rod.pdf
Source (Inventor): 07-drivewheel_rod.ipt
STL-file: 07-drivewheel_rod.stl
Amount needed: 1
08-drivewheel_tube
Drivewheel for tube
Drawing: 08-drivewheel_tube.pdf
Source (Inventor): 08-drivewheel_tube.ipt
STL-file: 08-drivewheel_tube.stl
Amount needed: 1
Adapter 6805er-Lager auf 22mm
Drawing: 09-22mm_6805_bearing_adaptor.pdf
Source (Inventor): 09-22mm_6805_bearing_adaptor.ipt
STL-file: 09-22mm_6805_bearing_adaptor.stl
Amount needed: 1
10-bed_arm_left_8mm
Bed arm left for 8mm rod
Drawing: 10-bed_arm_left_8mm.pdf
Source (Inventor): 10-bed_arm_left_8mm.ipt
STL-file: 10-bed_arm_left_8mm.stl
Amount needed: 1
Bed arm right for 8mm rod
Drawing: 11-bed_arm_right_8mm.pdf
Source (Inventor): 11-bed_arm_right_8mm.ipt
STL-file: 11-bed_arm_right_8mm.stl
Amount needed: 1
Drawing: 12-bed_z_mount_bracket.pdf
Source (Inventor): 12-bed_z_mount_bracket.ipt
STL-file: 12-bed_z_mount_bracket.stl
Amount needed: 1
Plattformträger rückwärtige Befestigungs-Clips
Drawing: []
Source (Inventor): []
Amount needed: 2
15mm-Rohrhalter (muss noch konstruiert werden)
Drawing: []
Amount needed: 2
Plattformträger vordere Befestigungs-Clips
Drawing: []
Amount needed: 2
Hall-Sensor-Halter
Drawing: []
Amount needed: 3
Motoranschluss für Gewindestange
Drawing: []
Amount needed: 1
17-Morgan_arm_PSI_a
Morgan-Arm PSI mit Kabeldurchführung
Drawing: []
Amount needed: 1
18-Morgan_arm_PSI_b
Drawing: []
Amount needed: 1
Morgan-Arm Theta (Innenachse)
Drawing: []
Amount needed: 1
Morgen-Arm Theta (Außenachse)
Drawing: []
Amount needed: 1
21-Morgan_toolhead
Drawing: []
Amount needed: 1
21-Morgan_toolhead_V3 (alternative)
Base for the V3 bowden hotend from RepRap-Fab.org.
Drawing: 21-Morgan_toolhead_V3.pdf
Source (Inventor): 21-Morgan_toolhead_V3.ipt
STL-file: 21-Morgan_toolhead_V3.stl
Amount needed: 1
Gewindestangenmutter Alpen 8mmSDS
Drawing: []
Amount needed: 1
Bowden-Adapter (Seilzugadapter) für den Extruder
Drawing: []
Amount needed: 1
Cap_2
Endkappe (8mm Loch, 16mm Gewinde)
Drawing: []
Amount needed: 2
Großes Fischgrätgetriebezahnrad für den Extruder
Drawing: []
Amount needed: 1
Prusa-Extruderblock
Drawing: []
Amount needed: 1
Prusa-Zwischenrad-Block
Drawing: []
Amount needed: 1
Kleines Fischgrätgetriebezahnrad für den Extruder
Drawing: []
Amount needed: 1
Noppenmutter M4 für den Extruder
Drawing: []
Amount needed: 1
TighteningCone_2
Konische Befestigungsklemme
Drawing: []
Amount needed: 2
Hardware
M3 nut
M3 grub screw 6mm (or suitable replacement bolt
M4 nut
M4 bolt 40mm
M4 bolt 80mm
M8 nut
M8 washer
M8 spring washer
M8 washer 28mm
M8 Nylock Nut
M8 Bolt 40mm
M8 Bolt 100mm
M8 Bolt 60mm
2mm self tapping coach screws, 40mm
15mm brass pipe 440mm
15mm brass pipe 200mm
22mm brass pipe 460mm
8mm threaded rod 650mm
8mm smooth rod
hard spring (idler compression) 7mm
8mm soft spring (lead screw anti backlash)
cabinet coach screws, 5mm
