User:RobertKuhlmann/RepRap Morgan BOM
< User:RobertKuhlmann
Revision as of 05:34, 10 July 2013 by RobertKuhlmann (talk | contribs) (Printed parts)
Under construcution
This article is the extended version of a material list for the RepRap Morgan.
Please feel free to add missing parts or correct mistakes.
Thanks to Quentin Harley for his permission to do this and for his outstanding Morgan-project.
Printed parts
You find the original SCAD-file from Quentin Harley, that does all parts, over here: Original Morgan SCAD-file
I've redrawn some of the parts to ease modifications without scripting.
01-pvc_pipe_support_a
Socket for PVC-pipe with cable hole
Drawing: 01-pvc_pipe_support_a.pdf
Source (Inventor): 01-pvc_pipe_support_a.ipt
STL-file: 01-pvc_pipe_support_a.stl
Amount needed: 2
02-pvc_pipe_support_b
Socket for PVC-pipe
Drawing: 02-pvc_pipe_support_b.pdf
STL-file: 02-pvc_pipe_support_b.stl
Source (Inventor): 02-pvc_pipe_support_b.ipt
Amount needed: 2
03-z_mount_bottom_8mm
Z-axis base for 8mm axes
Drawing: 03-z_mount_bottom_8mm.pdf
STL-file: 03-z_mount_bottom_8mm.stl
Source (Inventor): 03-z_mount_bottom_8mm.ipt
Amount needed: 1
04-z_mount_top_8mm
Z-Achsenbasis oben für 8mm Achse
Drawing: []
Source (Inventor): []
Amount needed: 1
05-motormount_short
Kurze Motorhalterung
Drawing: []
Amount needed: 1
06-motormount_tall
Lange Motorhalterung
Drawing: []
Amount needed: 1
07-drivewheel_rod
Antriebsrad für Stange
Drawing: []
Amount needed: 1
08-drivewheel_tube
Antriebsrad für Rohr
Drawing: []
Amount needed: 1
09-22mm_6805_bearing_adaptor
Adapter 6805er-Lager auf 22mm
Drawing: []
Amount needed: 1
10-bed_arm_left_8mm
Plattformarm links für 8mm Achse
Drawing: []
Amount needed: 1
11-bed_arm_right_8mm
Plattformarm rechts für 8mm Achse
Drawing: []
Amount needed: 1
12-bed_z_mount_bracket
Plattformträger Z-Achse
Drawing: []
Amount needed: 1
13-bed_rear_mountclips
Plattformträger rückwärtige Befestigungs-Clips
Drawing: []
Amount needed: 2
15mm pipe holders – To be done
15mm-Rohrhalter (muss noch konstruiert werden)
Drawing: []
Amount needed: 2
14-bed_front_mountclips.stl
Plattformträger vordere Befestigungs-Clips
Drawing: []
Amount needed: 2
15-hall_endstop_holder
Hall-Sensor-Halter
Drawing: []
Amount needed: 3
16-leadscrew_shaft_motor_mount
Motoranschluss für Gewindestange
Drawing: []
Amount needed: 1
17-Morgan_arm_PSI_a
Morgan-Arm PSI mit Kabeldurchführung
Drawing: []
Amount needed: 1
18-Morgan_arm_PSI_b
Drawing: []
Amount needed: 1
19-Morgan_arm_Theta_a
Morgan-Arm Theta (Innenachse)
Drawing: []
Amount needed: 1
20-Morgan_arm_Theta_b
Morgen-Arm Theta (Außenachse)
Drawing: []
Amount needed: 1
21-Morgan_toolhead
Drawing: []
Amount needed: 1
21-Morgan_toolhead_V3 (alternative)
Base for the V3 bowden hotend from RepRap-Fab.org.
Drawing: 21-Morgan_toolhead_V3.pdf
Source (Inventor): 21-Morgan_toolhead_V3.ipt
STL-file: 21-Morgan_toolhead_V3.stl
Amount needed: 1
22-Leadscrew-nut_Alpen8mmSDS
Gewindestangenmutter Alpen 8mmSDS
Drawing: []
Amount needed: 1
23-extruder_bowden_adaptor
Bowden-Adapter (Seilzugadapter) für den Extruder
Drawing: []
Amount needed: 1
Cap_2
Endkappe (8mm Loch, 16mm Gewinde)
Drawing: []
Amount needed: 2
Eckstruder_Big_Gear_Herringbone
Großes Fischgrätgetriebezahnrad für den Extruder
Drawing: []
Amount needed: 1
Eckstruder_Block_for_Prusa
Prusa-Extruderblock
Drawing: []
Amount needed: 1
Eckstruder_Idler_Block_for_Prusa
Prusa-Zwischenrad-Block
Drawing: []
Amount needed: 1
Eckstruder_Small_Gear_Herrinbone
Kleines Fischgrätgetriebezahnrad für den Extruder
Drawing: []
Amount needed: 1
thumb_knob_M4_extruder
Noppenmutter M4 für den Extruder
Drawing: []
Amount needed: 1
TighteningCone_2
Konische Befestigungsklemme
Drawing: []
Amount needed: 2
Hardware
M3 nut
M3 grub screw 6mm (or suitable replacement bolt
M4 nut
M4 bolt 40mm
M4 bolt 80mm
M8 nut
M8 washer
M8 spring washer
M8 washer 28mm
M8 Nylock Nut
M8 Bolt 40mm
M8 Bolt 100mm
M8 Bolt 60mm
2mm self tapping coach screws, 40mm
15mm brass pipe 440mm
15mm brass pipe 200mm
22mm brass pipe 460mm
8mm threaded rod 650mm
8mm smooth rod
hard spring (idler compression) 7mm
8mm soft spring (lead screw anti backlash)
cabinet coach screws, 5mm
