User:RobertKuhlmann/RepRap Morgan BOM
This article is the extended version of a material list for the RepRap Morgan.
Please feel free to add missing parts or correct mistakes.
Thanks to Quentin Harley for his permission to do this and for his outstanding Morgan-project.
Printed parts
You find the original SCAD-file from Quentin Harley, that does all parts, over here: Original Morgan SCAD-file
I've redrawn some of the parts to ease modifications without scripting.
01-pvc_pipe_support_a
Socket for PVC-pipe with cable hole
Drawing: 01-pvc_pipe_support_a.pdf
Source (Inventor): 01-pvc_pipe_support_a.ipt
STL-file: 01-pvc_pipe_support_a.stl
Amount needed: 2
02-pvc_pipe_support_b
Socket for PVC-pipe
Drawing: 02-pvc_pipe_support_b.pdf
STL-file: 02-pvc_pipe_support_b.stl
Source (Inventor): 02-pvc_pipe_support_b.ipt
Amount needed: 2
03-z_mount_bottom_8mm
Z-Achsenbasis unten für 8mm Achse
04-z_mount_top_8mm Z-Achsenbasis oben für 8mm Achse
05-motormount_short Kurze Motorhalterung
06-motormount_tall Lange Motorhalterung
07-drivewheel_rod Antriebsrad für Stange
08-drivewheel_tube Antriebsrad für Rohr
09-22mm_6805_bearing_adaptor Adapter 6805er-Lager auf 22mm
10-bed_arm_left_8mm Plattformarm links für 8mm Achse
11-bed_arm_right_8mm Plattformarm rechts für 8mm Achse
12-bed_z_mount_bracket Plattformträger Z-Achse
13-bed_rear_mountclips Plattformträger rückwärtige Befestigungs-Clips
15mm pipe holders – To be done 15mm-Rohrhalter (muss noch konstruiert werden)
14-bed_front_mountclips.stl Plattformträger vordere Befestigungs-Clips
15-hall_endstop_holder Hall-Sensor-Halter
16-leadscrew_shaft_motor_mount Motoranschluss für Gewindestange
17-Morgan_arm_PSI_a Morgan-Arm PSI mit Kabeldurchführung
18-Morgan_arm_PSI_b Morgan-Arm PSI mit Kabeldurchführung
19-Morgan_arm_Theta_a Morgan-Arm Theta (Innenachse)
20-Morgan_arm_Theta_b Morgen-Arm Theta (Außenachse)
21-Morgan_toolhead
Base for a bowden hotend.
Drawing: []
Source (Inventor): []
Amount needed: 1
21-Morgan_toolhead_V3
Base for the V3 bowden hotend from RepRap-Fab.org.
Drawing: 21-Morgan_toolhead_V3.pdf
Source (Inventor): 21-Morgan_toolhead_V3.ipt
STL-file: 21-Morgan_toolhead_V3.stl
Amount needed: 1
22-Leadscrew-nut_Alpen8mmSDS
Gewindestangenmutter Alpen 8mmSDS
23-extruder_bowden_adaptor Bowden-Adapter (Seilzugadapter) für den Extruder
Cap_2 Endkappe (8mm Loch, 16mm Gewinde)
Eckstruder_Big_Gear_Herringbone Großes Fischgrätgetriebezahnrad für den Extruder
Eckstruder_Block_for_Prusa Prusa-Extruderblock
Eckstruder_Idler_Block_for_Prusa Prusa-Zwischenrad-Block
Eckstruder_Small_Gear_Herrinbone Kleines Fischgrätgetriebezahnrad für den Extruder
thumb_knob_M4_extruder Noppenmutter M4 für den Extruder
TighteningCone_2 Konische Befestigungsklemme
