User:Bsutton
Revision as of 08:35, 7 July 2011 by Bsutton (talk | contribs) (manual install)
I'm going to use this page to record my trials and tribulations with getting a RepRap printer working.
July 7th
Downloaded the reprap host software and began the saga of getting it installed
FYI: my desktop is Ubuntu 11.04 x64
Found a couple of debian packages but neither of these work.
1) Found the ppa by Jonathan Marsden but this doesn't appear to be in working order: ppa install
2) The host git repository also has a debian package, however this appears less complete than Jonathans and again doesn't appear to work.
So I've decided to try and update then so one of them does work. The question is which one to start from?
manual install
Before I attempt to start building a debian package I thought it might be useful to work out how to get it to install manually.
The following is a log of my efforts and failures. brett's manual install
On my first attempt I received the following error:
./reprap
Exception in thread "J3D-Renderer-1" java.lang.UnsatisfiedLinkError: javax.media.j3d.NativeScreenInfo.openDisplay()J
	at javax.media.j3d.NativeScreenInfo.openDisplay(Native Method)
	at javax.media.j3d.NativeScreenInfo.getStaticDisplay(NativeScreenInfo.java:48)
	at javax.media.j3d.NativeScreenInfo.isGLX13(NativeScreenInfo.java:36)
	at javax.media.j3d.NativeConfigTemplate3D.getBestConfiguration(NativeConfigTemplate3D.java:67)
	at javax.media.j3d.NativePipeline.getBestConfiguration(NativePipeline.java:3241)
	at javax.media.j3d.Renderer.doWork(Renderer.java:488)
	at javax.media.j3d.J3dThread.run(J3dThread.java:256)
So the UnsatisfiedLinkError basically means that its looking for a entry point javax.media.j3d.NativeScreenInfo.openDisplay in a shared library. This feels like a compatibility issue! e.g. the shared library doesn't match my jar.
After much research I found a fix for this. Basically its an incompatability issue the fix for which is described here [j3dcore install]
July 1st
Headline text
I've order the mechanical parts for a Mendel-Prusa on ebay from Investalator.
Cost $USD160 Shipping $USD45 (ouch)
