Updating RepRap Firmware config.g file
The 'config.g' file
To configure a Duet board for a given machine, you have only to edit a file named 'config.g', located on the SD card in the /sys directory. This file is read and executed at startup, but the configuration can be modified later, either by executing a macro or entering commands in the web interface. These configuration modifications will be lost at next startup.
All configuration parameters are entered via 'G' and 'M' parameters, so the reprap firmware G-Code set is relatively extended. A config.g file could be reexecuted via the 'M999' command or an emergency stop.
It shall be noted that a malformed file may hang your board, and this apply to all macros executed by the 'config.g' file.
The first configuration, which shall define name, password and net configuration, will probably be done while writing the file on the SD card, as it is not wise to start a machine with an unverified file, except if you can independently supply logic and power on your board.
Any text editor could be used for modification.
After uploading the file in the SD card, inserting it in the board (while power is shutdown), restarting and connecting to the board, you have other solutions to modify the config.g file without removing the SD card.
Updating 'config.g'
For the updating of the config.g file, you have two solutions if your board connect properly:
- Using the incorporated editor in the web interface, but that doesn't work with all browsers, notably not with Microsoft browsers.
That editor is accessed in the "settings" window, sub-panel "configuration file".
- Editing the config.g file and uploading it via FTP. This have the advantage that you always have an up to date copy of your configuration file in your computer.
To log in FTP, you shall use the machine name as defined in the config.g file, for the user name any name e.g. 'whatever' and the password as defined in the config.g file (the leading 'P' indicates parameter and is not part of the name nor password) You could be simultaneously be logged in FTP and in http (web interface). If you have difficulties to connect directly in FTP, connect first with the web interface, this helps FTP connection.
Beware to upload in the /sys directory.
To upload/download to the SD card via FTP, you need a FTP client program (NOT a FTP server) and there is a wide choice for all systems. On Windows, you could use the FTP function of the file viewer 'Total Commander', FileZilla or WinSCP. On Linux, there is a default ftp client named 'ftp'. On a MAC you can use CyberDuck or FileZilla.
How to configure Duet
There are a few links which may help to configure your board
- Configuring RepRapFirmware for a Cartesian printer
- Configuring RepRapFirmware for a CoreXY printer
- Configuring and calibrating a delta printer using the dc42 fork of RepRapFirmware
- T3P3 guide to the config.g and homing files for Cartesian printers
- Preconfigured config.g files for various printers: https://github.com/reprappro/RepRapFirmware/tree/test/SD-image and https://github.com/dc42/RepRapFirmware/tree/dev/SD-image
- RepRapPro guide for commissioning Duet-based printers, including updating firmware: https://reprappro.com/documentation/commissioning-introduction/commissioning-duet/. You may also find their wiring diagrams for the Ormerod, Huxley and Mendel useful.
- Duet troubleshooting guide: https://reprappro.com/documentation/troubleshooting-introduction/electronics-problems/
- Temperature converter calibration (M301 is now M305) http://forums.reprap.org/read.php?340,326029
- DC42 fork allow external driver to be connected on the expansion connector and remapped with [| M569 ]. See http://forums.reprap.org/read.php?178,552124,552305
- Using Duet with wifi router on blog.think3dprint3d.com
- Using thermocouples with the Duet and RepRapFirmware
How do I know that my config.g have been properly executed
Without a LED and if you do not succeed in connecting your board, you can check that the config.g is properly executed by making 'music' with your steppers.
You shall execute a file (or inserting commands it in the config.g file itself), as the last command of your config.g.
It is possible to make sound using motors. The frequency is the step frequency, so moving at a defined speed give a note. However, the frequency for a given speed depends from the step/mm ratio and each sound file shall be adapted for a given step/mm ratio. As most printers driven by a duet haven’t any local screen nor diagnostic LED, the sound may indicate proper startup.
You may call a separate macro as the last command of your config file, e.g.
M98 P/macros/startmusic.g ; call a sound file to acknowledge the startup
You could create a music file by using this converter: http://en.homeconstructor.de/converter-convert-music-in-g-code.html On a delta printer, you shall move in Z only, to have all your motor running simultaneously with the effector speed equal to the carriage speed. On a Cartesian printer, you can use whatever axis, provided the step/mm is accurate. It is wise to limit the travel, so the converter will make back and forth travel within the defined range. The file provided by the converter shall be modified:
- Replace all G01 by G1
- Comments shall be prefixed by “;”
- add "G92 X0 Y0 Z0" at the beginning of the code, to define the origin as current position, as you have not yet homed the machine
- add "G91" to set absolute moves.
A better control on a delta may be to move each carriage independently, hence checking driver and stepper independently. A movement on 'XYZ' columns instead of 'XYZ' user space is done while adding S2 parameter to the G1 command. Unfortunately, this does only work in relative mode, so you shall convert the file from absolute to relative. Use a spreadsheet program to help conversion.
Example for 100 step/mm
100 step/mm -> example 16 teeth GT2-2, micro-step 1/16, 1.8° stepper Z travel up total 8mm. Works ok for 200 step/mm (same with 0.9° steppers)
8 first notes of French children song 'Quand on fait des crêpes'
; en.homeconstructor.de MIDI-converter version: 2.5 ; File: crepes.mid ;Breaks disabled ;Steps per millimeter for Z-axis: 100 G21 ; units are mm - supersedes former value, may not be needed G90 ; Absolute positioning - supersedes former value, shall be the default except for extruder G94 ; feed rate in units/minute, shall be the default G92 X0 Y0 Z0; set origin to current position, required as machine is not homed G1 Z1.23600000 F197.76000000 G1 Z1.60312500 F176.22000000 G1 Z2.42712500 F197.76000000 G1 Z3.30012500 F209.52000000 G1 Z4.28012500 F235.20000000 G1 Z5.10412500 F197.76000000 G1 Z6.41212500 F156.96000000 G1 Z7.64812500 F197.76000000 M84; shut down motors
for 87 steps/mm (like Fisher delta)sound shall be
G1 Z1.42068966 F227.31034483 G1 Z1.84267241 F202.55172414 G1 Z2.78979885 F227.31034483 G1 Z3.79324713 F240.82758621 G1 Z4.91968391 F270.34482759 G1 Z5.86681034 F227.31034483 G1 Z7.37025862 F180.41379310 G1 Z8.79094828 F227.31034483
