Universal Controller Board v1.3
Note: development on Kicad boards should be done in the electronics/universal-1.3 directory in subversion
Already Done
- Add debug LED's to Tx and Rx (nophead)
- Add debug LED's to min/max sensors (nophead)
- Add RJ11 Tx/Rx connections. (Zach Smith)
TODO List
- Add ICSP header components (Eric Frias)
- Slightly Enlarge holes on .100 headers
- Layout board in Kicad
- Test LED modifications on v1.2.1 board with 'green wire' mods.
- Fastener holes: ensure clearance fit for 1/8" (3.125mm) diameter shank (Imperial equivalent of M3). Dia 3.5mm should do it.
- Fastener washer space: ensure circuits avoid the radius of an M3 washer on the fastener holes (metal washers might short the circuit).
- More space for heater transistor heatsink (ensure clearance on heater LED)
- Avoid running high-amp power tracks through the board. Use multiple vias if transit is unavoidable.
- Add LEDs/220Rs to Alt 1 and Alt 2 power transistors - keep clearance for heatsinks.
