Tripodmaker
Release status: unknown
Description | End of life documentation
License | None
Author | |
Contributors | |
Based-on | |
Categories | None
CAD Models | |
External Link |
As of December 31st 2017 - Tripodmaker ended their production and support.
All support documentation can be found here.
Manual Tripodmaker Classic
Manual Tripodmaker Black Edition
Cura installation info for slicing
Set-up parameters Machine dimensions
dimensions | Tripodmaker Classic | Tripodmaker Black Edition | Tripdmaker Black Edition with doors | Tripodmaker Black Edition v2 |
X (width) [mm] | 300 | 300 | 200 | 200 |
Y (depth) [mm] | 300 | 300 | 200 | 200 |
Z (height) [mm] | 390 | 450 | 450 | 420 |
Other specifications
- Build plate shape: elliptic
- Heated bed: checked
- Machine center is zero: checked
- Gcode flavor: Repetier
- Printhead settings and Gantry height: Leave as is
- Nozzle size: 0.4mm
- Material diameter: 1,75 mm
Start code
;Home
G28
G1 X0 Y-100 Z030 F5000
;Prime the extruder
G92 E0
G1 F200 E30
G92 E0
End code
M104 T0 S0
M140 S0
;Retract the filament
G92 E1
G1 E-1 F300
G28 X0 Y0
M84
Print settings Infill
- Hollow: 0 percent
- Normal: 10 percent
- Strong: 25 percent
- Solid: 100 percent
Material settings
materials | ABS | PLA | PET | Wood | Flex 45 | ASA |
Volume flow 0,4 mm nozzle [mm3] | 2,4 | 3,5 | 2,4 | 3 | 0,9 | 2,4 |
Volume flow 0,8 mm nozzle [mm3] | 4,8 | 7 | 4,8 | 6 | / | 4,8 |
Print Temperature [Celcius] | 255 | 215 | 230 | 215 | 260 | 260 |
Bed Temperature [Celcius] | 90 | 60 | 70 | 60 | 0 | 90 |
Retraction Retract Speed [mm/s] | 25 | 25 | 25 | 25 | 25 | 25 |
Retraction Prime Speed [mm/s] | 25 | 25 | 25 | 25 | 25 | 25 |
Retraction Amount [mm] | 2 | 3 | 3 | 3 | 0 | 3 |
Retraction Hop [mm] | 2 | 0,075 | 0,075 | 0,075 | 0,075 | 0,075 |
Speed top/bottom [mm/s] | 20 | 20 | 20 | 20 | 15 | 20 |
Speed bottom layer [mm/s] | 20 | 20 | 20 | 20 | 15 | 20 |
Enable print cooling | No | Yes | Yes | Yes | No | No |
Speed settings Normal speed These settings are the fastest possible settings to maintain a print that finishes for 90 percent successfully. Printing slower will result in better finish and better reliability.
Normal settings from Prisma are 60 percent of the fast settings.
Fast speed Infill speed [mm/s] = volume flow [mmˆ3] / layer height [mm] / nozzle size [mm]
- Outer wall speed [mm/s] = 0,6 x Infill speed [mm/s]
- Inner wall speed [mm/s] = 0,6 x Infill speed [mm/s]
- Speed top and bottom [mm/s] = 20mm/s
- Support infill speed [mm/s] = 0,6 x Infill speed [mm/s]
- Support roof speed [mm/s] = 0,6 x Infill speed [mm/s]
Example PLA on 0,1 layer height and with 0,4 mm nozzle:
Fast Infill speed = 3,5 mmˆ3 (volume flow) / 0,1 mm (layer height) / 0,4 mm (nozzle size) = 87,5 mm/s fast speed Other speeds: 0,6 x 87,5 mm/s (Infill speed) = 52,5 mm/s
Normal Infill speed = 52,5 mm/s x 0,6 = 31,5 mm/s Other speeds = 18,9 mm/s
