Tripodmaker
Tripodmaker
Release status: unknown
End of life documentation
None
None
As of December 31st 2017 - Tripodmaker ended their production and support.
All support documentation can be found here.
Manual Tripodmaker Classic
Manual Tripodmaker Black Edition
Cura installation info for slicing
Set-up parameters Machine dimensions
Tripodmaker Black Edition | Tripdmaker Black Edition with doors | Tripodmaker Black Edition v2
300|300|200|200
300|300|200|200
390|450|450|420
Other specifications
  • Build plate shape: elliptic
  • Heated bed: checked
  • Machine center is zero: checked
  • Gcode flavor: Repetier
  • Printhead settings and Gantry height: Leave as is
  • Nozzle size: 0.4mm
  • Material diameter: 1,75 mm
Start code
Home
G28 G1 X0 Y-100 Z030 F5000
Prime the extruder
G92 E0 G1 F200 E30 G92 E0 End code M104 T0 S0 M140 S0
Retract the filament
G92 E1 G1 E-1 F300 G28 X0 Y0 M84
Print settings Infill
  • Hollow: 0 percent
  • Normal: 10 percent
  • Strong: 25 percent
  • Solid: 100 percent
Material settings
	ABS	PLA	PET	Wood	Flex 45	ASA
Volume flow 0,4 mm nozzle [mm3] 2,4 3,5 2,4 3 0,9 2,4 Volume flow 0,8 mm nozzle [mm3] 4,8 7 4,8 6 / 4,8 Print Temperature [Celcius] 255 215 230 215 260 260 Bed Temperature [Celcius] 90 60 70 60 0 90 Retraction Retract Speed [mm/s] 25 25 25 25 25 25 Retraction Prime Speed [mm/s] 25 25 25 25 25 25 Retraction Amount [mm] 2 3 3 3 0 3 Retraction Hop [mm] 2 0,075 0,075 0,075 0,075 0,075 Speed top/bottom [mm/s] 20 20 20 20 15 20 Speed bottom layer [mm/s] 20 20 20 20 15 20 Enable print cooling No Yes Yes Yes No No
Speed settings Normal speed These settings are the fastest possible settings to maintain a print that finishes for 90 percent successfully. Printing slower will result in better finish and better reliability.
Normal settings from Prisma are 60 percent of the fast settings.
Fast speed Infill speed [mm/s] = volume flow [mmˆ3] / layer height [mm] / nozzle size [mm]
  • Outer wall speed [mm/s] = 0,6 x Infill speed [mm/s]
  • Inner wall speed [mm/s] = 0,6 x Infill speed [mm/s]
  • Speed top and bottom [mm/s] = 20mm/s
  • Support infill speed [mm/s] = 0,6 x Infill speed [mm/s]
  • Support roof speed [mm/s] = 0,6 x Infill speed [mm/s]
Example PLA on 0,1 layer height and with 0,4 mm nozzle:
Fast Infill speed = 3,5 mmˆ3 (volume flow) / 0,1 mm (layer height) / 0,4 mm (nozzle size) = 87,5 mm/s fast speed Other speeds: 0,6 x 87,5 mm/s (Infill speed) = 52,5 mm/s
Normal Infill speed = 52,5 mm/s x 0,6 = 31,5 mm/s Other speeds = 18,9 mm/s
Additional Windows software:
Additional Mac OS X soft ware:
Netfab for mac:
Components to print
Trouble shooting
