TinyCut
Revision as of 10:28, 22 February 2013 by Blaise35u (talk | contribs)
Grille =http://www.ebay.fr/itm/Computer-PC-120mm-Chrome-Silver-Metal-Fan-Wire-Grill-Finger-Guard-Protection-New-/271011527262?pt=AU_Components&hash=item3f198bba5e air flow =http://www.ebay.fr/itm/120mm-AC-220V-Sleeve-Bearing-Cool-Case-Cooling-Fan-2PIN-/190500151886?pt=UK_Computing_Case_Fans&hash=item2c5ab1a24e filtre =http://www.ebay.fr/itm/ORIGINAL-HEPA-13-FILTER-H13-EFH-13W-WASCHBAR-AEG-ELECTROLUX-PHILIPS-TORNADO-H-13-/121064026727?pt=LH_DefaultDomain_77&hash=item1c2ffa7267
Tiny Cut
Release status: concept
a tansportable laser cutter
Laser
Now school project we want to develop, a transportable laser cutter. We base our work on the FoldaRap2 because we work in the same lab as Emmanuel. Goals of this project: We want to develop this machine using off-the-shelves parts or existing projects and technologies. We want to be able in this project to create a tiny laser cut portable in less than 4 month.
Concurrence
Concurrence
With 600€ you go to an small laser cut http://www.ebay.fr/itm/High-Precise-and-High-Speed-USB-CO2-Laser-Engraver-Engraving-Cutting-Machine-/170934801974?pt=LH_DefaultDomain_3&hash=item27cc821636
Specifications
  • Printed Parts: 20-21
  • Non-Printed Parts: Laser tube, Power laser, optical part, laser water cooling, air boost,
  • Cost: 400 €
  • Cutting Size: 200mm x 200mm
  • Resolution : a voir ?? mm and ?? mm
  • Speed: ?? mm/s
Special Features
  • Mobile!
  • Modular
  • Innovative
  • Based on standard/cheap 20x20mm aluminium extrusion (with 6mm slot)
  • Easy to build, with few tools (the printed parts are based on a 20mm grid (for overall aesthetic and mostly to ease the design), are generally 3-4mm thick, and fit the beams in a way you have nothing to measure during the assembly
  • Whith a real CO2 laser tube
  • Little (the entire machine is going to be about 30*30*30)
  • Big RED Power Security (my favorite detail ^^)
  • Cut surface about 200 x 200 mm
  • Easy to place on the material (it the machine witch go on the material, not the material witch go inside the small machine)
R&D
notre facebook
Inspiration
Some details that I found interesting or related or want to integrate to this idea of a portable laser cutter ...
External links, media/press, etc.
We like feedback from the community:
  1. marinosaurus page mention to be doing this project.
  2. User:Marinosaurus
History // forecast
  • 2013/02: beginning
  • 2013/03: Bills of materials, sourcing, buying
  • 2013/04: Developing CO2 and printing test, Receving the part.
  • 2013/05: Assembling work, and presentation of the project for our school.
Bill of Material Tiny Cut
