Thermoplast Extruder Variations
Revision as of 13:54, 3 October 2008 by Ronanwarrior (talk | contribs) (Section formating)
Design
  • Direct Drive -Does not use flexible steel cable)
  • Geared - Goes slower, but provide more control on the amount extruded)
  • Grub Screw in lower end of PTFE Insulator to help hold the brass barrel when using higher temperatures
  • Drive screw can be smooth for most of it's length. It reportedly only needs about 7 complete threads to dig in, the rest just add friction.
Materials
Barrel
    • Machined out of a brass bolt.
    • Aluminum has been used successfully.
    • Combination of stiff copper tubing and copper plate brazed together was used by Forrest Higgs.
Orifice
  • Mechanical pencil tip was reported to have heating problems.
Barrel dielectric material
  • Furnace cement is now the officially recommended material.
  • Both High-Temp JB weld and bar-b-que paint degrade after a hundred hours or so.
Pump
Insulator
  • Originally designed to be made from PTFE (Teflon
  • PEEK (w/o fiberglass reinforcement is reported to work)
  • Concrete has been reported not to work (tried by vik, who still hasn't supplied details)
  • Drywall mud (shrinks and cracks horribly, tried by John Gilmore)
