Template:RepRapPro mini extruder drive assembly
Revision as of 12:21, 16 January 2013 by Adrianbowyer (talk | contribs)
You will need one drive for each colour/material that your Mendel will print, up to a maximum of three. This section describes the parts for one drive.
Item Quantity
Large internal gear (printed) 1
Small push-fit gear (printed) 1
Main block (printed) 1
Tongue (printed) 1
PCB clips (printed) 2
Slotted custom PCB clip (printed) 1
Flat motor spacer (printed) 1
M3 nuts 5
M3 nyloc nuts 3
30mm M3 caps 2
35mm M3 caps 1
25mm M3 caps 1
25mm M3 screw (threaded to the top) 1
20mm M3 caps 3
12mm M3 caps 1
M3 spring washer 1
M3 washers 13
3mm 623 bearings 10mm OD x 4mm thick 3
8mm M3 hobbed drive 1
Short NEMA 17 motor 1
