Template:RepRapPro Melzi Current Setting
Revision as of 18:05, 18 January 2013 by Adrianbowyer (talk | contribs) (Setting the Motor Currents)
There are four small potentiometers on the Melzi PCB. These set the current that the stepping motor driver chips on the PCB will send to the motors.
It is very important to set these correctly, as the Melzi PCB is deliberately designed to be able to drive bigger motors than most RepRaps use (to allow for upgrades and enhancements). This means that it is possible to set the currents too high, which will damage the motors, and possibly the Melzi PCB.
The wiper on each potentiometer generates a DC voltage that is sent to the chip. The bigger the voltage, the higher the current that the chip will send to the motor.
These voltages should be set to 0.4V and this section tells you how to do it.
Make sure you are working on an insulating surface and that nothing that conducts electricity can touch any part of the Melzi PCB.
Start by putting the jumper (red arrow) across the two pins closest to you in the picture. This will power all the logic of the Melzi from the USB.
Set your meter to read volts, and connect it's negative/common wire to the negative power screw terminal on the Melzi. Screw it in securely, but don't over-tighten it.
Plug your Melzi into your computer using its USB cable. The Melzi's LED should come on.
Put the other meter probe (+ volts) on the single solder tab at the left of each potentiometer. Take very great care not to short to any other connection or component with the probe. You may have to stab the connection quite hard to get a reading - the soldering of the board can coat the solder with a thin insulating layer of flux.
Use a small screwdriver to turn the potentiometer until the meter reads 0.4 volts. This doesn't have to be accurate to 10 decimals - somewhere between 0.39 and 0.41 volts is fine.
Do this for each of the four potentiometers in turn.
The vast majority of potentiometers increase the voltage by turning clockwise. But a tiny few work backwards... Note down which way you need to turn the pots to increase the voltage. You may need that information later.
When you have finished disconnect the USB, and then remove the screwed-in meter connection.
If you are building a multi-material/multi-colour RepRap then repeat the above current setting steps for the second controller board. Then put that to one side for later.
Technical note on how the currents are regulated
You don't need to know this, but it is interesting...
The stepping motors are powered at 12 volts (Mendel) or 19 volts (Huxley). If you measure the resistance of one of the motor's coils, you will find that they are around 3 ohms. This implies a current of 4A if you were to drive them from, say, 12V, which is far too much. We need 1 A.
The driver chip could regulate the 12V down to 3V to get that correct current of 1A. But then it would be dissipating 9V x 1A x 2coils = 18 watts. That's soldering-iron power, and the chip would fry.
So what it does instead is to use pulse-width modulation (PWM): it sends an ultrasonic square wave to the motor and varies its mark-space ratio to give an average current of 1A. The MOSFETs in the chip are then either fully off (high voltage but zero current, so no power dissipation at all) or fully on (high current, but very low voltage, so very small power dissipation). That way the chips stay at a sensible temperature. When your RepRap is working properly they should be around 10 oC above ambient.
The chips can then also do clever things with the PWM to energise the coils in smoothly varying proportions. They do this to give you microstepping. The motors have 200 steps per revolution, but the driver chips can cause them to 'hang' part-way between two poles to position the rotation much more precisely than 1/200 of a revolution. This both gives much finer resolution, and much less jerky movement.
Why, you may wonder, not use motors with a higher resistance to avoid all this fancy footwork needed from the controller chips? The answer is that fine control - the chips can sense the instantaneous current that the motors are drawing, and also the back EMF that they generate when they move. Because they have lots of drive current to spare and are driving a low resistance, they can do clever tricks to overcome the delays that would otherwise be caused by such things as the motor's inductances. If you examine the actual signal that the driver chips send down the wires to the motors on an oscilloscope you will see that it is very complicated indeed.
This complexity means that you can't realistically measure the motor currents using - say - a simple meter. But you can set the control voltage going into the chips that decides its average. That is what you did above.
You will see throughout these instructions that we go on and on about disconnecting the power before changing any wiring. This is incredibly important, especially given the way the stepper motors are controlled as just described. As you can now imagine, if you disconnect a stepper motor wire while the motor driver chip is powered up, the chip sees the current fall to zero, so it compensates to increase the current. But it's well nigh impossible to disconnect any mechanical connector cleanly - the contacts always make and break as the wire is sliding. So when a break becomes a make the chip is trying to drive the motor at full blast, with the result that one or both of them will go BANG!, then never talk to you again...
