Template:Firmware Support Cell
Revision as of 13:32, 23 January 2018 by S2KTS (talk | contribs)
Usage
If you put:
{{Firmware Support Cell | avbl=Yes}}
Then you will get:
Parameters
avbl
Put the firmware's availability here. The default value is ???. If you put "Yes", "Partial", "Experimental" or "No", the background color will be set for corresponding color.
align
You can override the cell's "text-align" attribute with this parameter. The default is center.
style
You can add or override the cell's "style" attributes with this parameter.
