TechZoneHuxley
General
This page and its sub pages should guide you through assembling a RepRap Huxley from the TechZone kit, or from parts you have printed which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (24 Dec 2010)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access the assembly instructions pages from this page, or from the Main Huxley page.
Before you get started, I recommend browsing through all the different assembly sections, so that you have an Idea of what will be coming (it helps to keep you from second guessing what needs done next). You will find that a clean work area, with a good work surface will save you lots of time, and help keep the frustration level down. TechZone has tried very hard to make this kit as complete as possible, if you find that there are some essential parts missing, which should be included in the kit, please contact us [here] and let us know.
Unpacking the Huxley Kit
On the left is a picture of the parts which come in the Huxley Kit:
Nut and Bolt Set
Printed Parts Set
Extruder
Extruder Hardware
Extruder Printed and LaserCut parts
Thick Sheet Set
Belts
Bar Set
Motors
Monotronics Electronics set
Miscellaneous Items
Assembly Instruction Links
I know it would have been more convenient for most of you if these links had been at the top of the page, but it is important that you look through your kit and make sure all your items are there, before you begin assembly.
Files
The files needed to print and make your own Huxley, without buying the kit can be downloaded from here:
FILE ID# | TYPE | DESCRIPTION | AVAILABLE FORMATS | CREATED/RESERVED BY |
TechZone Huxley Printable Parts | TechZone variation of the Huxley | These are printable .stl files for the Huxley, the way TechZone did it. | .stl.zip | --Kimberly Andrus (TechZone) 12:00, Dec 24, 2010 (UTC) |
TechZone Huxley Thick Sheet Set | TechZone variation of the Huxley | This is the Thick Sheet set, the way TechZone did it. | .cdr.zip, .svg.zip | --Kimberly Andrus (TechZone) 12:00, Dec 24, 2010 (UTC) |
TechZone Huxley Bowden Extruder Gears | TechZone variation of the Huxley | This is the Gears Used in the TechZone Bowden Extruder. | .cdr.zip, .svg.zip | --Kimberly Andrus (TechZone) 12:00, Dec 24, 2010 (UTC) |
