Taurino/fr
Release status: Working
Description | Taurino a 100% Arduino Mega 2560 V3 compatible device
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | Altium
External Link |
Summary
Taurino is a 100% compatible Arduino Mega 2560 V3 board, it exists in two different versions, Taurino Power and Taurino Classic.
The Taurino Power is designed to run from 12V up to 35V powered thru the RAMPS shield. The Taurino Classic is designed to run with 12V from RAMPS shield. Both also work as Arduino boards powered thru USB.
Safety Tip
Once you start putting electricity into your RepRap - even at just 12 volts - you have to take basic, common sense precautions to avoid fires.
Just in case these fail, test your workshop smoke detector.
Got no smoke detector? Get one!
Taurino Power and Taurino Classic USB Driver for Windows
- NEW : Easy driver setup for Windows 8/7/Vista/XP 32 and 64 bit
File:RRD RUMBA TAURINO DriverSetup.zip
- CLASSIC: (can cause problems with Windows 8 and Vista/7 64bit, use the easy method from above instead)
When you attach your Taurino for the first time to a Windows computer you might need to provide a driver (INF file). File:RRD-Taurio Power USB DRIVER.zip
Taurino Classic
Description | Taurino Classic 100% Arduino Mega 2560 V3 compatible
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | Altium
External Link |
Features
- compact size: 108mm x 54mm
- Arduino 2560-R3 compatible
- can be used with 12V
Bootloaders
Original Arudino Mega 2560 V3 bootloaders are used
Source: Arduino bootloader
Taurino Power
Description | Taurino Power 100% Arduino Mega 2560 V3 compatible and capable of up to 35V
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | Altium
External Link |
Features
- ATmega16U2 (with enhanced firmware) for high speed USB serial connection (up to 2MBit)
- UNIVERSAL POWER:
- can be used with 12V-35V (e.g. RAMPS board with 24V can supply voltage (via D1) to TAURINO for standalone operation no damage of ATmega2560 possible due to to high power supply (e.g. from RAMPS or external connector)
- integrated high precision power regulators 5V (ATmega2560/Logic)
ATmega 2560 STK500v2/Arduino2560 Bootloader
HEX: File:RRD-Taurino Power ATmega2560 ArduinoBoot.hex.zip
FUSES: E: 0xFD / H: 0xD8 / L: 0xFF
- BOD=2.7V
- ISP=ENABLED
- BOOTSZ=4k
- BOOTRST=ENABLED
- EXTXOSC_8MHZ_XX_16KCK_65MS
16U2 LUFA/Arduino based USB2Serial Firmware
HEX: File:RRD-Taurino Power ATmega16U2 USB2Serial.hex.zip
FUSES: E: 0xF6 / H: 0xD9 / L: 0xFF
- BOD=2.7V
- ISP=ENABLED
Source: File:RRD-TAURINO SRC 16U2 FIRMWARE.zip (Atmel Studio 6 project)
Open Source Files
You can find the open source files here: http://forum.reprapdiscount.com/forums/oss/
Where to get it?
If you don't have the mood to build it yourself you can just buy direct from our ReprapDiscount Online Shop
