Stepper Chunks
Revision as of 20:10, 10 July 2017 by Colinrgodsey (talk | contribs) (Segment/Wave Table)
Direct stepper chunk support is a feature that allows device firmware to process stepper movement buffers (chunks) directly from a host device. This is done with a binary protocol that allows the host to buffer chunks to the device, and trigger them using the trigger command. This allows the firmware to free up processing cycles that can be used to achieve higher step rates, while allowing more advanced processing to be done on the external device.
The general flow involves the external host software taking on the role of "g-code consumer" and acts as a man-in-the-middle between the g-code source and the target device.
Formats
CH-4x4-128
This is the first proposed general format. It encodes 4 motors each with a 4-bit/8-step segment that produces 4x128 segments, a total chunk size of 256 bytes, spanning 1024 ticks total. This format is ideal for 8-bit processors as it requires very little unpacking and most iterators and indexes can be used as 8-bit values. Each 4-bit segment value is the movement delta (in steps) + 7, over 8 ticks. So a segment value of 8 would be a movement of +1 steps over 8 ticks. The 8-step segment resolution could technically suffer from some precision loss, but only at high speeds that would already suffer precision loss due to momentum.
Bit format (2 bytes per segment):
|----segment----|
XXXXYYYY ZZZZEEEE XXXXYYYY ZZZZEEEE
Segment/Wave Table
Any formats that include segments larger than 1 step generally requires a wave table to produce the actual step sequence for each segment. Other methods can be used, like Bresenham lines, but low-bit chunk formats work just fine with a simple segment sequence lookup table.
Example table for CH-4x4-128:
uint8_t segment_moves[16][8] = {
 { 1, 1, 1, 1, 1, 1, 1, 0 }, //  0 = -7
 { 1, 1, 1, 0, 1, 1, 1, 0 }, //  1 = -6
 { 0, 1, 1, 0, 1, 0, 1, 1 }, //  2 = -5
 { 0, 1, 0, 1, 0, 1, 0, 1 }, //  3 = -4
 { 0, 1, 0, 0, 1, 0, 0, 1 }, //  4 = -3
 { 0, 0, 1, 0, 0, 0, 1, 0 }, //  5 = -2
 { 0, 0, 0, 0, 1, 0, 0, 0 }, //  6 = -1
 { 0, 0, 0, 0, 0, 0, 0, 0 }, //  7 =  0
 { 0, 0, 0, 0, 1, 0, 0, 0 }, //  8 =  1
 { 0, 0, 1, 0, 0, 0, 1, 0 }, //  9 =  2
 { 0, 1, 0, 0, 1, 0, 0, 1 }, // 10 =  3
 { 0, 1, 0, 1, 0, 1, 0, 1 }, // 11 =  4
 { 0, 1, 1, 0, 1, 0, 1, 1 }, // 12 =  5
 { 1, 1, 1, 0, 1, 1, 1, 0 }, // 13 =  6
 { 1, 1, 1, 1, 1, 1, 1, 0 }, // 14 =  7
 { 0 }
External Links
Current proposal for Marlin
Step Daemon
