Smoothieboard
Revision as of 20:32, 9 November 2014 by Arthurwolf (talk | contribs)
SmoothieBoard
Release status: Working
32bits powerful and simple to configure electronics
Smoothieboard is a controller board for Reprap 3D printers. It is a descendant of other Reprap electronics like RAMPS, RAMBO and Melzi.
The main design change from older boards that is uses a more powerful ( ARM 32bits ) Cortex-M3 Microcontroller.
The board is named Smoothieboard, and the firmware that runs on it is called Smoothie.
The Smoothie project's main design goals are :
  • Ease of use and configuration
  • High performance ( faster speeds, smoother motion, thus the name )
  • Also works for laser cutters and CNC mills
  • Ethernet ( web interface ) support
  • Easy to contribute to, feature-rich
  • Strong documentation effort ( beginner-friendly, coherent, up to date documentation )
Features
  • Smoothieboard
    • ARM-Cortex M3 LPC1769 ( 120Mhz, 64kB RAM, 512kB Flash ) Microcontroller
    • USB2 interface
    • Ethernet interface
    • MicroSD card slot ( comes with a 4GB SD card, filled with documentation and host/slicing software packages )
    • 5 stepper motor drivers ( A4982, for stepper motors rated up to 2 Amperes ), well cooled on-board, 1/16 microstepping
    • Digital current control ( no need to use a screwdriver to set a potentiometer for current setting )
    • 3 ZXMN4A06 ( 5A, up to 24V ) small mosfets for hotends and fans
    • 3 AOT240L ( 12A, up to 24V ) big mosfets for hotends, fans and heated beds
    • 12 to 24V power input
    • Optional Voltage Regulator so the board can run without a host computer
    • 4 Thermistor inputs ( 12bit ADC ) for thermistors
    • 6 Endstop inputs
    • Extensions : SPI, I2C, PWM, DAC, free GPIOs
    • Un-pluggable screw terminal connectors for easy wiring
    • Everything broken out for easy hacking and inventing of new things
    • Open-Source Hardware, community developped
  • Smoothie firmware
    • Designed to take advantage of Smoothieboard's higher processing power
    • Motion control code was initially a port of the popular GRBL firmware
    • Supports all features found in Reprap firmwares
    • Compatible with the normal Reprap ecosystem ( G-code flavour ), making it compatible with the common Reprap Hosts ( Pronterface, Octoprint etc )
    • Easy configuration using a simple configuration file on the SD card ( no compiling/flashing required )
    • Serial interface over USB
    • Mass storage ( exposes the SD card content allowing for easy access to the configuration file ) over USB ( simultaneous with the Serial interface )
    • Ethernet support exposing Telnet, HTTP ( Web interface ) and SFTP interfaces.
    • High step rate ( 120khz ) for higher movement speed or high microstepping
    • Many improvements to the motion control code allowing to use the higher processing power for more correct and smoother motion control
    • Longer and faster look-ahead for acceleration
    • Supports alternative arm solutions beyond cartesian : Linear delta ( Rostock ), H-Bot/CoreXY, Morgan Scara, Feather
    • Also supports laser cutting, CNC milling, paste extrusion
    • Support for arbitrary number of extruders and hotends
    • Support for arbritrary number of "switches" ( configurable G-code controlled inputs or outputs )
    • Touchprobe support ( autolevelling and auto-calibration )
    • PID control and PID auto-tuning
    • Support for several common "panel" controllers
    • Easy firmware upgrade via the SD card
    • Modular and well commented code
    • Simple to contribute to ( modular design means you only have to add/edit one file to add a feature )
    • Integrated debugger support ( DFU for flashing and MRI for GDB )
    • Wiki-based documentation with a large coverage, and an emphasis on being beginner-friendly
    • Community reaching outside of 3D printing resulting in additional features and code/documentation contributions
