Smartrap Build Manual/fr
Revision as of 05:07, 26 October 2014 by Smartfriendz (talk | contribs) (Installation logiciels et préparation)
Smartrap Mini | How to Get Smartrap | Smartrap Build Manual | How to Use Smartrap | Smartrap Improvements
Welcome to the official document of the Smartrap's assembly.
Each step of building should take around one minute.
Tools you need:
  • Small screwdriver plate for M3
  • Bigger screwdriver for M6
  • Allen key 1mm
Printed parts
plate_base plate_base plate_x plate_x plate_y plate_y
Bottom.jpg bottom endx_huxley endx_huxley endx_back endx_back
glass_holder bottom glass_support endx_huxley z_coupler endx_back
direct_drive bottom belt_axis endx_huxley belt_tensioner endx_back
Non printed parts
Pre-assemble the head
head 1 1 head 2 2 head 3 3
head 4 4 head 5 5 head 6 6
head 7 7 head 8 8 head 9 9
head 10 10
Bottom / base
base 1 1 base 2 2 base 3 3
base 4 4 base 5 5 base 6 6
base 7 7 base 8 8 base 9 9
base 10 10 base 11 11 base 12 12
base 13 13
Y axis
y 1 1 y 2 2 y 3 3
y 4 4 y 5 5 y 6 6
y 7 7 y 8 8 y 9 9
y 10 10 y 11 11 y 12 12
y 13 13 y 14 14 y 15 15
y 16 16 y 17 17 y 18 18
y 19 19 y 20 20 y 21 21
y 22 22
Extruder
y 1 1 y 2 2 y 3 3
y 4 4 y 5 5 y 6 6
y 7 7
X axis
x 1 1 x 2 2 x 3 3
x 4 4 x 5 5 x 6 6
x 7 7 x 8 8 x 9 9
x 10 10 x 11 11 x 12 12
x 13 13 x 14 14 x 15 15
x 16 16
Z axis
z 1 1 z 2 2 z 3 3
z 4 4 z 5 5 z 6 6
z 7 7 z 8 8 z 9 9
z 10 10
Wiring
wire 1 1 wire 2 2 wire 3 3
wire 4 4 wire 5 5 wire 6 6
wire 7 7 wire 8 8 wire 9 9
wire 10 10 wire 11 11 wire 12 12
wire 13 13 wire 14 14 wire 15 15
wire 16 16 wire 17 17 wire 18 18
wire 19 19 wire 20 20 wire 21 21
wire 22 22 wire 23 23 wire 24 24
Finishing
finish 1 1 z 2 2 z 3 3
z 4 4 z 5 5 z 6 6
Nous avons maintenant notre Smartrap assemblée, il nous reste a installer,configurer les logiciels.
Logiciels dont vous aurez besoin :
Arduino : Votre carte électronique est composée de deux parties. Une (celle du dessous) est la carte la plus standard de controle pour plusieurs milliers de projets open source:La carte arduino ( mega 2560 rev3). C’est une tres bonne idée de tele charger et installer le logiciel pour cette carte. Vous ne l’utiliserez peut être pas tout de suite car nous avalons preinstallé le firmware, mais cela viendra vite afin d’ajuster des paramètres non accessibles depuis la ligne de commande Repetier host. Un très bon effet de bord est que le logiciel de reconnaissance et contrôle de la carte pour votre système est installé en meme temps , pour tous les systèmes.
Repetier host : C’est le logiciel de control de l’imprimante. Ce logiciel inclus un autre ( tous open source bien sur) :
slic3r: c’est le logiciel de decoupage et preparation des modeles 3d au format stl en commandes pour l’imprimante. Les paramètres que nous allons ajuster seront principalement utilisés par slic3r.
Installation
Télécharger et installer arduino.
Télécharger et installer repetier host. Le logiciel slic3r sera installé en meme temps.
Télécharger le fichier de configuration sur Smartfriendz github dépot. ( file : smartrap_slic3r_config.ini )
Initialisation
Connecter le cable USB entre votre imprimante et l’ordinateur
Ouvrez Repetier host
Cliquez sur le bouton “printer settings” . Selectionnez alors (si ce n’est pas les bonnes valeurs) 250000 pour le bitrate ( vitesse de communication entre l’ordinateur et l’imprimante).
Essayer de connecter l’imprimante avec le bouton “connect”. Un teste devrait défiler dans le panneaux de log (en bas). Le point important ici est de regarder la température.Elle devrait indiquer la température ambiante ( 15-25 degrés) and pas zero. Si vous avez zéro, il y a un problème de connection au niveau de la tete, ou du connecteur.
Brancher l’alimentation 12V.
Rendez vous sur “print panel” . Essayez de bouger les moteurs en cliquant sur les boutons correspondants et verifier si ils vont dans le bon sens + 1 X devrait faire venir l’axe X vers vous. +1 Y devrait déplacer le plateau vers la gauche. +1 Z devrait faire monter la tete.
Si un moteur va dans la mauvaise direction, le plus simple est de débrancher l’alimentation, retourner le connecteur du moteur sur la carte, puis retrancher l’alimentation.
Maintenant, sélectionnons le panneau “Slicer”
cliquez sur le bouton “configure” dans la partie “slic3r”. Cela devrait ouvrir une nouvelle fenêtre du logiciel slic3r.
Sélectionnez File->Load config , et prenez le fichier de configuration trouvé sur le depot github de smartfriendz. Lorsque c’est fini, vous pouvez fermer slic3r.
Reglage de la tete pour l’autolevelling
imprimer ! ( enfin)
