Smartrap Build Manual
Revision as of 05:19, 6 July 2014 by Smartfriendz (talk | contribs)
Smartrap Mini | How to Get Smartrap | Smartrap Build Manual | How to Use Smartrap | Smartrap Improvements
Welcome to the official document of the Smartrap's assembly.
Each step of building should take around one minute.
Tools you need:
  • Small screwdriver plate for M3
  • Bigger screwdriver for M6
  • Allen key 1mm
Printed parts
Non printed parts
Building steps
Step 1 Simply put the wood base on the table.
Step 2 Put on the 3 motors: Y, Z and extruder.
Step 3 We can add the electronics card in front.
NOTE: With Smartfriendz kits, it will be with a boxed controller with simpler connectors outside the box.
Step 4 We can already add the X motor (in the back), end stops, and plug everything. NOTE: with Smartfriendz kits, there will be color-coded cables and the right length.
(Missing here the maritime screw to add to the extruder motor. We need an 1mm Allen key.)
Step 5 Now we add the plate_base part and adjust the all motors to be ready to fix. We will use 8 M3 screws.
Step 6 Screwed :)
Step 7 Now we add the bearing on the extruder. It can go only after screws.
Step 8 We add the lm8uu on the plate_base
Step 9 Installing the plate_Y
Step 10 2 x M3 and 2 LM8 to install here.
Step 11 Now we can place the 2 Z-rods. It should be a little tight. Push them through the wood plank. It is stable because of the wood plank.
Step 12
Step 13
Step 14
Step 15
Step 16
Step 17
Step 18
Step 19
Step 20
Step 21
Step 22
Step 23
Step 24
Step 25
Step 26
Step 27
Step 28
Step 29
Step 30
Step 31
Step 32
Step 33
Step 34
Step 35
Step 36
Step 37
Step 38
