Smartrap Build Manual
Revision as of 05:02, 25 November 2013 by Smartfriendz (talk | contribs)
Welcome to the official doc of the smartrap's assembly.
I've tried to cut the building steps in one minute length step, more or less. So it's easy to follow and we can make coffee pause ( important).
Tools you need: - Small screwdriver plate for M3 - Bigger screwdriver for M6 - Alen key 1mm
Printed parts
Non printed parts
simply put the wood base on the table. | |
Put on the 3 motors : Y, Z and extruder. | |
We can add the electronics card in front. NOTE : with smartfriendz kits, it will be with a boxed controller with simpler connectors outside the box. | |
We can already add the X motor ( in the back), endstops, and plug everything . NOTE : with smartfriendz kits, there will be colour coded cables and the right length.
( missing here the maritime screw to add to the extruder motor. We need a 1mm alen key ! ) | |
Now we add the plate_base part and adjust the all motors to be ready to fix. We will use 8 M3 screws. | |
step 39 | |
step 40 |
