Smartrap Build Manual
Revision as of 19:15, 24 November 2013 by Smartfriendz (talk | contribs)
Welcome to the official doc of the smartrap's assembly.
Tools you need: - Small screwdriver plate for M3 - Bigger screwdriver for M6 - Alen key 1mm
Printed parts
Non printed parts
step 1 simply put the wood base on the table.
step 2 Put on the 3 motors : Y, Z and extruder.
step 3 We can add the electronics card in front.
NOTE : with smartfriendz kits, it will be with a boxed controller with simpler connectors outside the box.
step 4 We can already add the X motor ( in the back), endstops, and plug everything . NOTE : with smartfriendz kits, there will be colour coded cables and the right length.
( missing here the maritime screw to add to the extruder motor. We need a 1mm alen key ! )
step 5 Now we add the plate_base part and adjust the all motors to be ready to fix. We will use 8 M3 screws.
step 6
