Sanguish
Revision as of 00:02, 9 November 2012 by Bryanandaimee (talk | contribs)
Sanguish Electronics Board
Release status: experimental
All in one electronics with Toshiba drivers
[GPL]
(none)
Sanguish is an all-in-one electronics platform similar to Gen7 and Sanguinololu. The main difference is that Sanguish is using the through hole Toshiba TB6560AHQ drivers in place of the Pololu driver daughter boards. The main advantage is cost savings, as the Toshiba drivers are much less expensive than the Pololu boards. In addition it is likely that the Toshiba drivers will allow higher current motors to be used. The HZip form factor will be much easier to heat-sink, and the drivers will handle more current before requiring a heat sink than the Pololu drivers will.
Note: The enable line is inverted from the way it works on the Pololu drivers so this MUST be changed in firmware before powering on the 12V to the drivers, otherwise the smoke will escape.
How to get it
Don't even think about it. I haven't tested this board yet. But if you feel like living on the edge here is the pre-alpha release
File:Sanguish.zip
PCBs
No boards have yet been made or tested.
Components
Here is the preliminary Mouser project. Mouser project
It should have everything in it needed to build the basic board. No external parts are included. So cabling, end-stops, etc. are left to the user to source. You can of course use the Gen7_Endstop_1.3.1 or use mechanical end-stops. The mouser project is still pretty rough as the parts list is a bit fluid at the moment.
BOM comming soon(ish)
Parts Lists
Electronic Components
Miscellaneous
