Sanguinololu SD
Summary
A microSD card reader for the Sanguinololu RepRap electronics.
File:Http://reprap.org/mediawiki/images/thumb/7/73/Sanguinololu-sd-card-slot.jpg/800px-Sanguinololu-sd-card-slot.jpg
Where to get it?
It is currently sold already assembled - just plug it into your Sanguinololu. eMAKERshop: [1]
MOUNTING LOCATION File:Http://000vmm.s3.amazonaws.com/printrbot/files/2011/11/Sanguinololu-SD.png
FEATURES SUMMARY Our design has fewer parts than others out there, can handle up to 100MHz clock rate should the need arise, and has built-in ESD protection as well. Here's the datasheet: Media:http://www.ti.com/lit/ds/symlink/txb0104.pdf. There's a LDO linear regulator on the board for the 3.3V SD supply. SD cards typically use about 80mA so we went with a smaller regulator than the one Kliment used.
PINOUT 1. Chip select 2. N/C 3. N/C 4. N/C 5. GND 6. N/C 7. DI/CMD 8. CLK 9. 5V 10. DO
COMPATIBILITY This is also confirmed to work great on the Teensylu (by Steph the designer).
Our board isn't directly connectable to the RAMPS/Arduino Mega. You'd need an adapter board/cable of some sort. Theoretically, it should work with RAMPS, but the pins won't be plug and play like the other two mentioned above.
Geek note: Gcodes that relate to the SD card here: http://reprap.org/wiki/GCodes#M20:_List_SD_card
