SAV MKI
[[image:|center|190px]]
Description | SAV MKI
License | ???
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | |
External Link | (none)
Descripción.
This 3D printer board electronics has been designed and developed using all the great contributions and feedback from the RepRap CloneWars group in Spain. All shortcomings from other similar boards have been addressed providing an affordable yet feature rich 3D printer electronics.
Features
Feature rich yet affordable 3d printer electronics. The SAV MkI has been designed after taking feedback from the Clone Wars RepRapers out there. We have come through with an electronics that we believe will meet your expectations.
- Hotend and heatbed well dimensioned FETs that can take up to 15A without heat-sinks.
- High speed native USB interface connectivity going up to 8Mbps so that there is no lag on your prints.
- 12V built-in fan controller for your layer fan or hot end cooling.
- Micro SD reader for autonomous printing.
- Bluetooth dongle (dongle not provided, tested with HC-05 and HC-06) interface adapted to its logic levels for wireless operation.
- Expansion bus to connect a keyboard and LCD.
- Support for 4 standard pololu compatible stepper motor drivers.
Specifications
HW
Processor
Atmel AT90USB1286 Microcontroller @16 MHz Native USB interface Supply
Voltage input
12V-20V
Internal regulated voltage
5V and 3.3V
Logic supplied by on-board voltage regulator through Vin Logic can also be supplied through USB (internal source selection).
Connectivity
2 x 15A switching connectors 1 x switching N-MOSFET for low power fan. on board uSD connector Bluetooth interface output levels adjusted for 3.3V logic (connected to UART1 - Rx and Tx). Four Endstop connectors supplied @ 5V. Includes X, Y, Z and E 2 Thermistors 14 Extra pins available for expansion and development, with the following capabilities -- UART1 (RX and TX) -- I2C (SDA and SCL) -- SPI (MOSI, MISO, SCK) -- PWM pin (1) -- Analog I/O (6) -- JTAG (uses some of the ADC pins)
Dimensions
100mm x 65mm
SW, Firmware and SDK
- Marlin (pre-loaded) - Marlin´s main branch already supports the SAV-MkI (MOTHERBOARD==83)
- Bootloader: LUFA's CDC Bootloader
- SDK: Arduino IDE with Teensy add-on.
- Windows users only, will need to install USB Serial device (will be downloaded with the Teensy environment).
Highlights
Details
Design Goals
How to get it
Individual Components
Miscellaneous
Notice Regarding Legal Stuff
Development
History
External links
Indiegogo [1]
