Rostock Mini Pro Build Manual
Revision as of 01:56, 25 March 2014 by 3DBob (talk | contribs)
Rostock_Mini_Pro Documentation
BOM
Bowden Extrusion
2x Push-in Fitting
2x Teflon Tubing
1x 22-Teeth Steel Gear
Linear Motion
1x 625ZZ Bearing
6x LM8UU Bearing
6x 608ZZ Bearing
12x Traxxas 5347 U-joints
3x GT-2 36 Pulley
3x GT-2 Belt (1m)
3x Belt Spring Tensioner
Electronics
3x Endstopper
1x RAMPS 1.4 Assembled (modified for laptop charger)
3x Nema 17 Motor
1x Nema 17 Motor coupled with Planetary Gearbox
1x 12V 10A Laptop Charger
Frame
6x 8mm Hardened Zinc-coated Precision Rod (49cm)
6x 3K Carbon Fiber Tubes (15cm)
1x Acrylic Top Plate
1x Acrylic Bottom Plate
16x Rostock Mini Pro Printed Parts
Others
1x J-head MKIV Hotend
30x 3mm Zip-ties
Various Bolts and Nuts
