Rostock MAX
Introduction
Rostock MAX is a derivative based upon Johann's original Rostock Delta Printer Prototype. It features T-Slot extrusion for the linear motion ( cheapskate ) and laser cut acrylic OR melamine framework. The lower wrap piece around the bottom hides the electronics, but it's removable to show off all the acrylic/plywood and electronics if you want. The main goal of the MAX is to make a more rigid and sturdy version of the original using CNC machined, Injection molded and laser cut parts instead of printed and plywood pieces.
Photos
250px 250px Concept for triple hot-end 250px 250px 250px 250px
Videos
Bill of Materials
The following BOM is for completing a Rostock MAX. You may substitute many of the hardware pieces for metric equivalents if you have easier access to them, we tried to make sure that it would accept both where possible.
Rostock MAX B.O.M. | |||||
Quantity | Description | Notes | |||
Reference | STL's of ALL PARTS | File:10-11-12 ROSTOCK MAX RELEASE BY PARTDADDY SEEMECNC.zip These are .stl files of all parts for reference if needed | |||
Qty. 1 Set | DWG of only LASER PARTS | File:DWG 10-11-12 ROSTOCK MAX LASERFILES BY PARTDADDY SEEMECNC.zip These parts are may have modifications as time goes on, but they are a good baseline | |||
Qty. 3 | 32" long 1" T Slot | Have found that 20mm Misumi and 80/20 1" or 80/20 metric work equally as well | |||
Qty. 24 | 608ZZ Ball Bearings | Standard 608 Skate Bearings | |||
Qty. 16 | M3-.5 x 10mm L Pan Head Phillips | nema motor mounting screws | |||
Qty. 6 | M3-.5 x 6mm L Pan head Phillips | For attaching the motor pulleys | |||
Qty. 1 | Electronics Control | RAMPS, RAMBo, Sanguino etc... At the moment, printrboard doesn't have enough memory to support delta firmwares | |||
Qty. 4 | Nema 17 Size Stepper Motors | 42BYG811 or 42BYG804 or similar, 3 for the vertical axes and one for the extruder | |||
Qty. 1 | Optional Heated Bed | This is a must have for ABS. You can use a Phebe, Prusa PCB, or fab your own. Laser files have mount for Phebe from SeeMeCNC | |||
Qty. 1 | Hotend | Laser files have the mounts etc... for use with SeeMeCNC's own hotend | |||
Qty. 1 | Extruder | Laser files have the mounts etc.. for use with SeeMeCNC's "Steve's Extruder" setup for bowden drive | |||
Qty. 1 | ATX PSU | The mounts are on the laser files for a standard ATX PC power supply, If using a heated bed, use at least 400w | |||
Qty. 3 | 15 Tooth Motor Pulley | GT2 2mm pitch timing belt pulley, origional uses 40 tooth, you can use anything from 15 on up | |||
Qty. 3 | GT2 2mm pitch x 1905mm | open-ended is fine, and neoprene works fine | |||
Qty. 12 | CNC Machined U-joints | from SeeMeCNC | |||
Qty. 18 | Idler Bearing Spacers | from SeeMeCNC | |||
Qty. 12 | Cheapskate Eccentric tensioner Cams | from SeeMeCNC | |||
Qty. 18 | Cheapskate Fixed Bearing Spacer | from SeeMeCNC | |||
Qty. 6 | 2-56 X 5/8" Screws | For Endstops | |||
Qty. 6 | 2-56 Nuts | For Endstops | |||
Qty. 100 | 6-32 Nylon Locknuts | ||||
Qty. 65 | 6-32 X 1" Flat Head screws | ||||
Qty. 6 | 6-32 X 5/8" Socket Head Cap Screws (SHCS) | ||||
Qty. 21 | 6-32 X 2" SHCS | from SeeMeCNC | |||
Qty. 9 | 6-32 X 1 3/4" SHCS | ||||
Qty. 25 | 1/4-20 T Slot nuts | For sliding in the t slot channels | |||
Qty. 25 | 1/4-20 X 1/2" Button Head Screws | For t slot nuts | |||
Qty. 6 | 10-32 X 5/8" Pan Head Screws | NYLON for mounting feet | |||
Qty. 6 | 10-32 Nylon finish nuts | For mounting feet | |||
Qty. 6 | Rubber Feet | You can use any kind of rubbery foot on the bottom, we use our rubber feet | |||
Qty. 26 | #4 SAE Flat Washer | ||||
Qty. 12 | #4 X 1/4" Sheet Metal Screw (SMS) | ||||
Qty. 12 | #4 X 3/8" SMS | ||||
Qty. 27 | 4-40 Blind T-Nuts | These are the kind that press in from the back side and have barbs that keep them from turning | |||
Qty. 4 | 4-40 X 1 1/4" Pan Head Screws | ||||
Qty. 12 | 4-40 X 3/4" Pan Head Screws | ||||
Qty. 12 | 4-40 X 1/2" Pan Head Screws | ||||
Qty. 4 | 6-32 X 1/2" Nylon Pan Head | For mounting the ATX PS | |||
Qty. 50 | #6 SAE Flat Washer | ||||
Qty. 30 | Acetal Bearing slip-on covers | These are the tapered acetal pieces that slip over a 608 to ride on the t slot extrusion | |||
Qty. 6 | 1/8" dia. X 3 1/8" L axle/dowel | These are the axles that hold the U-joints to the carriages/platform | |||
Qty. 3 | 3/8" OD X 9/64 ID X 1" aluminum bushing | These are used to space the hotend plate up off the platform for more Z travel | |||
Qty. 2ft | 2mm ID X 4mm OD Teflon Tubing | This is the material for the Bowden Tube | |||
Qty. 2 | 4mm PTC fittings | These connect the bowden tube from the extruder to the hotend | |||
Qty. 6 | Parallel Delta Arms | From SeeMeCNC | |||
Qty. 6 | Folding Belt Clamps | These can be printed or purchased from SeeMeCNC | |||
Qty. 3 | Carriage U-Joint Mounts | These are in the .stl files, can be purchased from SeeMeCNC | |||
Qty. 1 | Platform | You can use the origional Johann platform, or the injection molded SeeMeCNC Platform halves (2 halves from SeeMe) | |||
Qty. 20 | 1/8" ID X 1/4" OD Spacers | These are used as standoffs under the heated bed mount and electronics (SeeMeCNC supplies acetal spacers) | |||
Qty. 1 | Switch for PSU | You can use a switch between the green wire and a ground wire on a PS to turn it on/off | |||
Qty. 1 | 1/8" Stickralon(tm) Polycarbonate Build plate | Stickralon is a polycarbonate material found by SeeMeCNC to be awesome as use for a build surface! | |||
Qty. 4-6 | Small Binder Clips | Also called bulldog clips, used to hold the build plate on | |||
Qty. 12 | small zip ties | for fastening wiring and making it cleaner | |||
Qty. 2 | Spool Axles | For supporting the filament spool on the extruder mount (lasercut or printed) | |||
Qty. 1 | Hot-End Spacer | 1/2" ID X 3/4" OD X 1/4" thick wood/aluminum spacer for the hotend where it mounts to the upper part of the platform | |||
Qty. 1 | 1/8" PVC or flexible material for bottom wrap | 6 1/8" wide by 48" long, can be PVC signboard, plywood, polycarb, anyting flexible enough to wrap around and enclose the electronics if you want to | |||
Qty. 4 | 10-32 X 1/2" Nylon Thumb Screws | Used to hold the decorative PVC warp on the base of the machine |
Feel free to add any other items not listed below here, by you the users
Software and Setup
While the Rostock MAX will work with any of the Reprap Host softwares, Repetier-Host has proven to be the most reliable, full featured and easy to set up and use.
Repetier Host
Repetier-Host is a great software package that bundles the toolpathing program Slic3r with a great machine control as well as gcode viewer all in one install. Download the current version for your operating system (Windows, Mac and Linux are supported) from http://repetier.com
SeeMeCNC has videos for installing and setting up repetier for the Rostock MAX on Installing Youtube
Installation:
1. Download and install Repetier-Host on your computer. It will automatically install the slicing program Slic3r with it, no need to go out and download it seperately.
2. Under Config/Printer settings, you will need to set up the printers COM port and Speed, and it helps to give the printer a unique name now, just highlight "default" and put your own name in there, then click on apply.
3. Now, go into the printer shape tab, and change printer shape to X=250 Y=250 Z=350 for starters. You will need to change these numbers once you learn the physical max movements of your machine in X Y and Z.
4. Also while in the Printer Shape tab, we need to change Home X and Home Y to 0 instead of Min or Max, and Home Z to Max.
5. Make sure "Has Dump Area" is un-checked, and enter HALF of your width negative in X min, and Half in X Max, and Bed Left should be equal to X min. So, if you entered 250 for Print Area Width, you would put -125 in X Min, 125 in X max, and -125 in bed left. Repeat the logic there for the Y axis min/max/bed front and make sure to click on "Apply"
6. If you made those changes right, your screen should now be showing you a tall box shaped print area, with a dot in the center of the table area, that represents your machine's zero point.
Electronics
RAMBo Boards
Rambo by UltiMachine is what was being used on the prototypes. RAMPS 1.4 was used as well. You only need 4 stepper drivers, 3 limit switch inputs, and two heating circuits (if using a heated bed) so any board capable of those requirements should be acceptable.
Installing the RAMBo USB driver for Windows
Download this file File:RAMBo USBdriver.zip and unzip it into a known location on your computer. In windows 7, plug in your RAMBo board, and let windows 'quietly' fail to find the driver. Then, go to the start menu, right click on computer and click properties. On the left, click on Device Manager. Scroll down to Unknown Devices, and right click on RAMBo. Choose Update driver. CLick on "Browse my computer for driver software", then click on "Let me pick from a list of device drivers on my computer", then click the button for "Have Disk" and then click browse and point it to the file you downloaded above. Then click OK and it will tell you the driver isn't signed, it's ok, install anyways, and enjoy!
Power Supply
450W ATX PSU is used to run all electronics, the lower acrylic/wood panels have mounts for a standard ATX PSU, as well as RAMPS 1.4, RAMBo and universal mounting holes for other electronics such as the RAMBo or RAMPS (arduino Mega)
Firmware
The Rostock MAX uses Delta based firmware. The firmware can be found at https://github.com/johnoly99/Marlin-for-rostockmax-rambo. That firmware can also be used on RAMPS or other electronics. It is Marlin RC2, But has Johann's delta mods, Tonokip's RAMBo mods, and johnoly99's MAX mods.
All of the settings relating to the delta geometry is located in the first marlin.pde file. The settings in the version linked above are maintained to work on the Rostock MAX, but changing the delta geometry could make it work on other 3 column parallel delta bots such as your own designs and iterations.
Assembly
Each of the following assembly steps build upon the previous step. Pay close attention to the laser cut pieces. There are some holes that have a scored circle around them. The scored line around the holes indicates that those holes need countersunk to put the 6-32 screws flush with the surface. If you have melamine wood laser cut parts, you can pick the melamine off the surface around the holes to where the scored line is, and the screw will bite into the MDF core without needing to use a countersink also. Another note is that it helps to leave the masking on the parts while assembling except where it would be impossible to remove once it's tightened down. That helps keep everything clean and free from scratches from tools while you're working on it.
Steve's Extruder assembly instructions are the same as SeeMe CNC's H-1 3D Printer:
File:71590 Steves Extruder Assembly.pdf
Photos of Steves Extruder
Step 1 - Base Assembly
Step 1.1 - Base Sub Assembly
Assemble the Base of the machine. Start by installing the 6 17505 LEG parts with the 10-32x5/8" pan head nylon screws with the nylon nut onto the 68355 BASE. The Part number on the Base part will be facing downward along with the legs. Once the legs are secured the 44010 FOOT can be installed on the LEG part. Next the 68352 TRI SUPPORT, 68377 TSLOT SUPPORT, and the 68364 MOTOR MOUNT will assemble together first before being attached to the BASE. This step will be repeated 2 more times so you will end up with 3 identical assemblies. Next select any 1 of these 3 assemblies and add 68356 POWER SUPPLY RETAINER to it opposite of the TSLOT SUPPORT part. The screws attaching these parts together can be fully tightened at this time. Next the 3 assemblies can be assembled with the base install all the screws making sure that you countersunk all the holes so that your screws will sit flush. It is best to leave these screws lose so the it is easier to install the TABLE part. At this point you may want to install the STEPPER MOTORS, 15T Timing Pullies, 608 idler bearings, and ATX POWER SUPPLY just for ease of assembly. Now it is time to add the 68361 COVER BRACKETS there are 7 of these around the outer edge of the BASE. The TABLE has lettering on it indicating an X, Y and Z column location. Take note that the X is the front-left column facing you, Y is the front-right, and Z is in the rear-middle position. That will help you know which axes is which when it comes to calibration/tuning if needed. The 2 Doors need to go on before you put the TABLE on, as they are held in with the tabs on them, into holes in the top/bottom plates. The door on the front (between X and Y columns) is where the RAMBo (or your own electronics) are meant to be mounted. There are holes already for RAMBo as well as the Arduino MEGA pattern(RAMPS 1.4), and fans to cool them if you need. You can mount them on the front or the back of the board, your choice. Before the TABLE part is added to the assembly be sure to install the 4-40 tee-nuts into the bottom side of the table, these are what is used to attach the UNO HEATED BED INSULATOR and the heated bed itself. You can tighten all the screws once the TABLE is installed on top of the Base sub assembly.
Step 1.2 - Stepper mounting and idler Assembly
Pay close attention to the score line on the sides of the lower T slot mounting plates. The line shows you where the end of the T slot should line up with, so that the machine is square and all three arms are equal lengths.
Step 2 - T slot upper
Assemble the top of the T Slot rails as shown, and repeat for all 3. They're all identical. The top of the rails should line up with the scored line on the upper laser cut plates. This helps in getting the machine square with all three columns identical in height. Note that the lower sections, on the base assembly, also have these lines to show you where to position the t slots before tightening.
Step 3 - Cheapskate
Assemble the 3 cheapskate carriages as shown, all 3 are identical. Make sure that you put the upper u joint mounts with the holes the same direction, that way your limit switch bolts will be in the same spot on all three. It's the hole that is drilled and tapped on the top/bottom of the black u joint mounts.
Once you have the cheapskate assemblies assembled, adjust the cam side until the bearings are good and snug. Then, adjust the 5th bearing, the one that pulls from the inside of the plates, so it is snug too. Now, slide the carriages up and down on the tslots for a while and you will feel them free up slightly. The acetal bearing covers can get dented if snugged and left in that position for a while. Snugging them down and running the carriages 'forms' them to the alumium t slot's radius, and they tend to stay put with that radius 'squeezed' into them. If the cheapskate starts to feel like it has a flat spot on it, snug the cam side and 5th bearing side down a bit tighter, and run the carriage up/down for a bit and re-seat the acetal.
Step 4 - Hot-End Platform
Step 4 is assembling the Platform and the u joints that carry it. The PDF shows the hot end and how it mounts, but you will want to leave the hot end off for now, until you are ready for wiring it in, it's easier to work with it off the machine. The most IMPORTANT step here is after the u joints are installed on the axles, and the platform is assembled, you will want to check the fit/tension of all 6 of the parallel arms at this point. The arms are made from a glass-filled nylon, and they are pretty strong. However, due to plastic injection molding, the tolerance of the "squeeze" on the u joints is hard to control. So, we intentionally mold them with a tight fit. All you need to do is snap them onto their u joints, and fell the friction of each joint. You want them to be tight, but not too tight. It should just take a tad more than their own weight to make them "drop" when you hold them horizontally. If they are too tight, you can lightly sand the insides of the arms where they snap over the u joints. It sands really easily, so careful not to sand too much.
Step 5 - Spool and Extruder mounting bracket
Step 6 - Final Frame Assembly
File:RostockMAX-Step6-Video.AVI
Motors
4 NEMA 17 stepper motors are needed. There is one motor for each of the three delta arms, and one for the extruder. You can substitute NEMA 11 thru 17 motors on the extruder, but the arms need more torque to lift the carriage.
Motors used in SeeMeCNC kits are
42BYGHW811
Other motors that should work well are
42BYGHW804
If you use other motors, be sure to list them and their performance here please.
NEMA 17's uses M3 X.5-10mm mounting screws.
Endstops
Uses 3 mechanical endstops located at the TOP of each column. Endstops are actuated and adjusted by screws located on the cheapskate u-joint mounts. Some limit switches provided by UltiMachine have tabs that can easily be bent at a 90 degree angle to allow the use of the connectors provided in the pre-wired endstop kits. For those, just simply bend them over and use the provided connectors or solder them onto the switches. If your RAMBo kit has switches with the short stubby connections on them, it is best to simply snip off the connectors and solder the wires directly to the endstops.
Make sure you connect the endstop wires to the switches in the NC (normally closed) position. One wire goes to the C or common terminal, and the other goes to NC terminal
Belts and Pulleys
The three columns use 75" long (~1905mm long) GT2 2mm pitch x 6mm wide open ended belt. 15 tooth machined aluminum pulleys are used on the prototype to increase torque and positioning accuracy. The pulleys use M3-.5 X 6mm screws to hold them onto the stepper shafts
Calibration
Because the Rostock MAX (as well as other deltas) use the X Y and Z axes to drive the columns up/down, the steps per mm MUST be the same for all 3 axes as well as the acceleration values. For the Rostock MAX, the default steps per mm using the 15 tooth timing pulleys and the Rambo electronics are 53.333 for the X Y and Z, and 292.000 for the extruder. All these values are based on 1/8 stepping, so you can modify these values for your own electronics.
The First step is to make sure each tower/arm is moving parallel to the table. To do this, home the machine by sending G28. Then, jog the platform down to about 5mm above the print surface, at the center. Take a measurement using calipers or something as precise as you can between the top of the platform and the print surface. Now jog the platform towards the Z column, the one in the very back. Get it close to the column, but not all the way to the arms being straight up and down. Now, take a measurement again with the calipers or such. If the platform is HIGHER at the column, then move the endstop screw up by that amount, and if the platform is lower, then move the endstop screw down by that amount. Repeat this process for the other two columns, and then go once more around the three columns. This should be good enough at this point.
The next thing to calibrate is the sweeping motion of the platform across the print surface. To do this, once again home the machine out with G28. Now, jog the platform down to about 5mm above the surface. Using your calipers etc... make a measurement as you did above. Now make slow (~1000mm/min) moves from X0 Y0 to X100 Y0 and measure the platform again. If the platform is raising "up" as it travels away from the center (X0 Y0) then you need to decrease the #define DELTA_SMOOTH_ROD_OFFSET. If it's lowering down, increase the #define DELTA_SMOOTH_ROD_OFFSET. Start by making .5mm changes to the value, and decrease the amount of the change as you get closer to perfect parallel movement.
Slic3r Settings
The following settings were used to calibrate retraction on the hollower pyramid thing at http://www.thingiverse.com/thing:29429. Filament used was Makerbot 1.8mm Silver ABS. Use these settings for a good general baseline for printing. You can increase the print speed, but you may need to increase hotend temps as you increase speed above 35mm/sec. 235C+ is looking to print well at 35mm/sec speeds
.3 layer height
2 perimeters
0% infill (hollow)
30mm/sec speeds for everything except for external perimeters at 80%
300mm/sec travel speed
228C extruder temp
slow down if print time is below 25 seconds
minimum print speed set to 6mm/sec
10mm retraction @ 55mm/sec retraction speed
0 Z lift
0 extra length on restart
3mm minimum travel after retraction
Further reading
"Rostock MAX on Indiegogo" The SeeMeCNC Campaign that kicked off the Rostock MAX kits
"Rostock Derivative", another RepRap built from extruded Aluminum in the Rostock arrangement.
