Rostock MAX
Revision as of 16:40, 21 September 2012 by Partdaddy (talk | contribs) (Bill of Materials)
Rostock MAX
Release status: experimental
Rostock MAX is a delta robot 3D printer based upon Johann's origional.
Coming Soon
Rostock MAX by SeeMeCNC.com
Introduction
Rostock MAX is based upon Johann's origional Rostock Delta Printer Prototype. It features T-Slot extrusion for the linear motion ( cheapskate ) and laser cut acrylic OR plywood framework. The lower wrap piece around the bottom hides the electronics, but it's removeable to show off all the acrylic/plywood and electronics if you want.
Photos
250px Rostock max small.jpg Upperidlerrensioner.jpg Withrambo.jpg Blinkyside.jpg Morepowah.jpg IMAG1184.jpg 250px Concept for triple hot-end 250px 250px 250px 250px
Videos
http://youtube.com/seemecnc
Bill of Materials
Rostock MAX B.O.M.
Qty. 9 608ZZ Ball Bearings The best you can source
Qty. 1 One Set of Laser Cut Parts File:ROSTOCK MAX BY SEEMECNC INITIAL RELEASE OPEN SOURCE.zip
Qty. 16 M3 x 10mm L Pan Head Phillip nema motor mounting screws
Qty. 4 Nema 17 Size Stepper Motors four wire steppers
Qty. 3 1" Square T-Slot (25mm) x 32"inch (800mm) long regular aluminum t-slot
Qty. 3 15T Idler Pulley GT2 2mm pitch timing belt pulley
Qty. 3 GT2 2mm pitch x 1900mm L timing belt neoprene works fine
Qty. ? 6-32 Ny Lock Nut Stainless 3mm or 3.5mm can be used instead
Qty. ? 6-32 x 1"L Phillip Flat Head Screw Stainless 3mm or 3.5mm can be used instead
Qty. 24 1/4-20 Button Head Screw x 1/2"L 6mm x 12mm L Screw for metric
Qty. 24 1/4-20 t-slot nut (ebay) use 6mm or proper metric size for 25mm t-slot
>_ >_
>_ >_
Electronics
RAMBo by UltiMachine is what is being used on the prototypes. RAMPS 1.4 has been used by Johann and others on the original which has the same requirements. You only need 4 stepper drivers, 6 limit switch inputs, and two heating circuits so any board capable of those requirements should be acceptable.
450W ATX PSU is used to run all electronics, the lower acrylic panels have mounts for a standard ATX PSU, as well as RAMPS 1.4, RAMBo and universal mounting holes for other electronics.
Firmware
The Rostock MAX uses the same firmware as the origional Rostock. It can be found Here. It is Marlin, with the Delta positioning so that any standard host can send X Y Z E moves to the board, using standard Gcode, and the firmware interprets the delta math to move the platform. Rod length and sin/cos are defined in the marlin.pde file, this is where the movements are calculated based on these values.
Assembly
STEP 1 ...
Motors
The Rostock MAX uses 4 NEMA 17 stepper motors. There is one motor for each of the three delta arms, and one for the extruder. You can substitute NEMA 11 thru 17 motors on the extruder, but the arms need more torque to lift the carriage.
Motors used in SeeMeCNC kits are
42BYGHW811
Other motors that should work well are
42BYGHW804
If you use other motors, be sure to list them and their performance here please.
NEMA 17's uses M3 X.5-10mm mounting screws.
Endstops
Currently, there are 6 endstops used for homing the delta arms. One on top and bottom of each arm. Changes are in the works by Johann to eliminate the bottom endstops, as the tops have micro adjustments already, so no need for the lower adjustable endstops.
Belts and Pulleys
Uses 74" long (~1900mm long) GT2 2mm pitch x 6mm wide belt. You will need three of these belts, one for each arm. Original Rostock uses 40 tooth pulleys, we are using 15 tooth machined aluminum pulleys on the prototype to increase torque and positioning accuracy.
Calibration
