Rostock MAX
Revision as of 22:02, 9 September 2012 by Partdaddy (talk | contribs) (Photos)
Rostock MAX
Release status: experimental
Rostock MAX is a delta robot 3D printer based upon Johann's origional.
Coming Soon
Rostock MAX by SeeMeCNC.com
Introduction
Rostock MAX is based upon Johann's origional Rostock Delta Printer Prototype. It features T-Slot extrusion for the linear motion ( cheapskate ) and laser cut acrylic OR plywood framework. The lower wrap piece around the bottom hides the electronics, but it's removeable to show off all the acrylic/plywood and electronics if you want.
Photos
250px Rostock max small.jpg Upperidlerrensioner.jpg Withrambo.jpg Blinkyside.jpg Morepowah.jpg IMAG1184.jpg 250px Concept for triple hot-end 250px 250px
Bill of Materials
Hardware
3 pcs. 32" long 1" (25mm) extruded aluminum T-Slot. Prototype uses 1" aluminum extrusion, 80/20 or similar. *Metric 25mm should work as well, all the laser cut parts accept metric extrusion as well as standard or metric hardware*
16 M3x.5 - 10mm long screws for mounting NEMA 17 stepper motors. (NEMA 11 and some 14's use M2.5x.5)
Laser Cut/Printable Parts
[Thingiverse hosted printable parts and lasercut/routed/milled pieces]
Electronics
RAMBo by UltiMachine is what is being used on the prototypes. RAMPS 1.4 has been used by Johann and others on the original which has the same requirements. You only need 4 stepper drivers, 6 limit switch inputs, and two heating circuits so any board capable of those requirements should be acceptable.
450W ATX PSU is used to run all electronics, the lower acrylic panels have mounts for a standard ATX PSU, as well as RAMPS 1.4, RAMBo and universal mounting holes for other electronics.
Firmware
The Rostock MAX uses the same firmware as the origional Rostock. It can be found Here. It is Marlin, with the Delta positioning so that any standard host can send X Y Z E moves to the board, using standard Gcode, and the firmware interprets the delta math to move the platform. Rod length and sin/cos are defined in the marlin.pde file, this is where the movements are calculated based on these values.
Assembly
Motors
The Rostock MAX uses 4 NEMA 17 stepper motors. There is one motor for each of the three delta arms, and one for the extruder. You can substitute NEMA 11 thru 17 motors on the extruder, but the arms need more torque to lift the carriage.
Motors used in SeeMeCNC kits are
42BYGHW811
Other motors that should work well are
42BYGHW804
If you use other motors, be sure to list them and their performance here please.
NEMA 17's uses M3 X.5-10mm mounting screws.
Endstops
Currently, there are 6 endstops used for homing the delta arms. One on top and bottom of each arm. Changes are in the works by Johann to eliminate the bottom endstops, as the tops have micro adjustments already, so no need for the lower adjustable endstops.
Belts and Pulleys
Uses 74" long (~1900mm long) GT2 2mm pitch x 6mm wide belt. You will need three of these belts, one for each arm. Original Rostock uses 40 tooth pulleys, we are using 15 tooth machined aluminum pulleys on the prototype to increase torque and positioning accuracy.
Calibration
