RobunDel
Revision as of 10:34, 22 May 2011 by ROTORIT (talk | contribs)
RobunDel
RobundDel Is a Mendel (like) printer only slightly bigger and more robust than a Standard one.
GPL
RobundDel Is a Mendel (like) printer only slightly bigger and more robust than a Standard one. All the threaded/smooth rods is 500mm long and the intention was to make the most use of the length of them in favor to gain a bigger build area without compromising on print speed and quality.
It is working but still in development and will be edited in the near future.
Lower frame corner vertex is made to fit 8mm threaded rods for the lower frame and 16mm rods for the upper frame.
Stl file for Vertex Lower
The Y motor brackets is also feet's to increase stability in the lower frame at the rods is as long as 500mm.
There is 2 of these as there is 2 stepper motors in the y axis.
STL file for Y Motor Bracket
