Reprappable-inkjet
Release status: experimental
Description | An inkjet head that can be completely made in a RepRap machine
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Introduction
This is an inkjet head that is completely makable in a RepRap machine. It was inspired by Johnrpm's Scratchbuilt_Piezo_Printhead.
It has only three reprapped parts. The other parts are standard easily-obtainable items. There is no machining involved in making it - the only tools needed are scissors, a scalpel or razor blade, a hammer, a short piece of 3 mm steel rod to use as a punch, and a glue gun.
It uses a piezoelectric buzzer to drive the ink.
It is experimental, so it's reliability is not yet perfect... But it does work (there's a video below).
I need to do more work on the driver electronics. Then I'll see if I can add heater elements so we can inkjet waxes and wood's metal...
Bill of Materials
no. off | part | picture key |
1 | reprapped body | A |
1 | reprapped tube clamp | B |
1 | ink supply | C |
1 | length of 3mm soft silicone tube | C |
2 | 25 mm M3 set screws | D |
2 | 20 mm M3 set screws | D |
4 | M3 nuts | D |
8 | M3 washers | D |
1 | reprapped buzzer clamp | E |
2 | 25 mm O rings, minor diameter 2 mm | F |
1 | sewing pin with a length of wire insulation | G |
1 | plastic disc | H |
1 | 27 mm diameter piezo buzzer element | I |
The plastic disc can be cut from any reasonably stiff piece of flat plastic. I used an old plastic box. Draw round the piezo buzzer element with a fine felt-tip pen then cut carefully inside your line with scissors. You want the disc and the buzzer to be the same size.
I used a syringe as my ink supply, but any small watertight container that you can connect to the silicone tube will do.
Construction
<videoflash type="vimeo">17782515</videoflash>
