ReplicatorG-Skeinforge-RAMPS
I built a RepRap Mendel with Wade's Geared Extruder.
I have it working already, but my Skeinforge settings are still way of.
Input and suggestions are greatly appreciated!
Here will be the place with the tweaks I did to get it going with ReplicatorG.
Computer: Mac OS X 10.6.7
Software: ReplicatorG 0024 and Skeinforge 0035
Firmware: Teacup Firmware
Hardware: RepRap Mendel with 3 endstops: XMin, YMax, ZMin
Extruder: Wade's extruder
Hotend: Phayzr Hotend (my own quick'n dirty heater design)
File: replicatorg/machines/reprap.xml
- In ReplicatorG->Preferences you need to check Show experimental profiles to be able to see these settings
<machine experimental="1"> <name>Mendel with Mega/RAMPS Electronics (115200 baud)</name> <geometry type="cartesian"> <axis id="x" length="200" maxfeedrate="5000" scale="47.069852" endstops="min"/> <axis id="y" length="200" maxfeedrate="5000" scale="47.0698523" endstops="max"/> <axis id="z" length="140" maxfeedrate="150" scale="160" endstops="min"/> </geometry> <tools> <tool name="Stepper-based extruder" type="extruder" material="abs" motor="true" floodcoolant="false" mistcoolant="false" fan="true" valve="false" collet="false" heater="true" motor_steps="3200" heatedplatform="false" default_rpm="5.5"/> </tools> <clamps></clamps> <help name="RepRap Help" url="http://www.reprap.org/ReplicatorG"></help> <driver name="reprap5d"> <rate>115200</rate> <parity>8</parity> <pulserts>true</pulserts> <waitforstart enabled="true" timeout="1000" retries="3"></waitforstart> <fived>true</fived> </driver> <warmup> </warmup> <cooldown> </cooldown> </machine>
File: config.h.ramps
- renamed to config.h
- softlimits undefined (to make repositioning via the ReplicatorG Controlpanel easy, will be reenabled after everything works)
- #define BAUD 115200
- #define XON/OFF
- ACCELERATION_REPRAP undefined
- ACCELERATION_RAMPING undefined
- Stepper settings:
- #define MAXIMUM_FEEDRATE_X 200
- #define MAXIMUM_FEEDRATE_Y 200
- #define MAXIMUM_FEEDRATE_Z 100
- #define MAXIMUM_FEEDRATE_E 600
- #define SEARCH_FEEDRATE_X 100 //was50
- #define SEARCH_FEEDRATE_Y 100
- #define SEARCH_FEEDRATE_Z 100 ///was 1???
- #define SEARCH_FEEDRATE_E 50
- #define E_STARTSTOP_STEPS 1 //this might need to be zero, will try later again
Board: RAMPS
- Stepper Jumpers:
- X = 1/16
- Y = 1/16
- Z = 1/16
- E = 1/4
Skeinforge settings:
Activate dimension Set to Relative
ReplicatorG settings:
Prferences: Generate separate Z steps (not sure this necessary) Attention! You ABSOLUTELY need to disable this again if you use ReplicatorG with a Makerbot Thing-O-Matic, it will make the head crash right into the build platform!!!
