RepSnapper Manual:Installation
Windows Installation
- download RepSnapper.exe here
- run RepSnapper using RepSnapper.exe (you will need OpenGL)
Non-Windows Installation
Dependancy Installation
Although RepSnapper is not generally tested outside of window/linux/mac you may be able to get it running on other OS's. To do so you will need the following:
- gcc and stuff
- OpenGL
- SVN
- libfltk1.1
- libfltk1.1-dev
- libglut3
- libglut3-dev
- libboost1.37 and -dev (or higher version)
Linux
Debian/Ubuntu
To install the dependencies listed above on Ubunutu or any debian-based linux run the following from prompt:
sudo apt-get install build-essential fluid libgtk2.0-dev libfltk1.1 libfltk1.1-dev libglut3 libglut3-dev libboost1.38-dev
For my configuration (Jolicloud, an Ubuntu derivative):
sudo apt-get install build-essential fluid libgtk2.0-dev libfltk1.1 libfltk1.1-dev libglut3 libglut3-dev libboost1.37-dev
libboost-thread1.37-dev libboost-system1.37-dev
For Ubuntu 10.04 use:
sudo apt-get install build-essential fluid libgtk2.0-dev libfltk1.1 libfltk1.1-dev libglut3 libglut3-dev libboost1.40-dev libboost-thread-dev libboost-system-dev
If you wan't to minimize dependencies, these are needed in addition to the ones above, but normally pulled in by being recommended by other packages:
libboost-regex-dev libboost-filesystem-dev
OS-X
RepSnapper Download
You can download the RepSnapper source using svn: http://svn.kulitorum.com/RepSnapper/
This git is out of sync with subversion (remove?): git clone git://github.com/timschmidt/repsnapper.git
OS-X
David Buzz made a binary distribution, you can get it here: https://sites.google.com/site/davidbuzz/repsnapper-for-osx-binaries
(RepSnapper-01-09-2010.dmg at the bottom of the page)
RepSnapper Installation
Linux
Check to have installed packages as descrided above
svn co http://svn.kulitorum.com/RepSnapper cd Repsnapper/Src make clean make (If you get a file/directory does not exist error (e.g. if using ubuntu 10.04) try this:) cd RepSnapper/Libraries/xml/ make cd ../../Src/ make
OS-X
Eclipse Project
As a new feature RepSnapper now comes with an Eclipse Galileo(3.5) project.
Grab a svn client like kdesvn and start the download.
Grab the Eclipse IDE for C/C++ Developers from the download page http://www.eclipse.org/downloads/
Throw in an additional SVN plugin - Help | Install New Software...
- Subclipse - http://subclipse.tigris.org/update_1.6.x
- Just take them all
Eclipse is Java and that means a svn wrapper. So shut down Eclipse and get it.
sudo apt-get install libsvn-java
Ubuntu users may wish to open the System|Administration|Synaptic Package Manager and do a quick search for libsvn instead as that will ensure Eclipse can find it.
When the donwload is complete enter the Eclipse folder in the repository and read the Readme.txt for last minute instructions.
At some point you'll need to reboot, so if you haven't done it before do it now.
Notice that while you downloaded the code with kdesvn you can now use svn directly from eclipse.
The build all works and so does the run and debug functionality, enjoy.
