RepRap Version II "Mendel"
Revision as of 03:39, 16 October 2009 by Skinnyed (talk | contribs) (Mendel Specifications)
The machine on the right is the RepRap printer, which we lovingly call "Mendel". It's the second, new-improved version: small enough to fit on your desk but with a print volume large enough for you to make big things (see specifications below). The machine is made up of bits bought in from local suppliers, and parts which it can make for itself - all the translucent structural components.
In the picture, behind the machine, you can see the RepRap software which you can use to print your thing. We give this, and the designs for the machine away, free - it's all open source. Though you do have to buy in some standard components from... well, whoever you want... which can cost up to £395. The idea of getting all the materials and building a machine yourself may seem daunting, but this area of the wiki is dedicated to making the whole process as easy as possible.
Instructions
The table below outlines most of the specifications used to benchmark 3D printers.
' UK metric US imperial
Manufacturer RepRap
Model Mendel
Technology FFF (Fused Filament Fabrication)/Thermoplastic extrusion
Price £395.00 $630
Annual Service Cost Occasional oiling = £5 Occasional oiling = $10
Size & Wt. 500 mm (W) x 400 mm (D) x 360 mm (H), weight TBC 20” (W) x 16” (D) x 14” (H), weight TBC
Build Envelope 200 mm (W) x 200 mm (D) x 140 mm (H) 8” (W) x 8” (D) x 5.5” (H)
Materials PLA, HDPE, ABS & more. Uses ø 3 mm filament. PLA, HDPE, ABS & more. Uses ø 0.118” filament.
Material Cost PLA: £20/kg, HDPE: £10/kg, ABS: £15/kg PLA: $14/lb, HDPE: $7/lb, ABS: $10/lb
Speed fair, TBC
Accuracy Resolution of nozzle 0.5 mm, 2 mm min. feature size, 0.1 mm positioning accuracy, layer thk 0.5 mm Resolution of nozzle 0.0196”, 0.0787” min. feature size, 0.0039 positioning accuracy, layer thk 0.0196”
Finish fair
Mendel vs. Darwin
Mendel is the latest generation RepRap machine. Mendel supercedes the first version, which we call Darwin. For RepRap Version I "Darwin" instructions follow this link.
Mendel has the following key improvements over Darwin:
  • Bigger print area, smaller machine footprint
  • Improved constraint on the z-axis to eliminate jamming
  • Better axis efficiency
  • Simpler assembly
  • Capacity of tool changing
This video illustrates these improvements:
<videoflash type="vimeo">6983001|640|480</videoflash>
For a numerical comparison see this blog post.
