RepRap Prusa ITA
Revision as of 03:41, 23 March 2011 by Lory90sw (talk | contribs) (Parti da Comprare)
REP RAP PRUSA traduzione da [Lory90sw]
Una delle tante versioni alternative della RepRap è la versione definita Prusa piu veloce e semplice da stampare rispetto alla mendel per altre info sulla storia della macchina vedere la sezione in [inglese] ecco alcuni esempi in alcuni video <videoflash>Y-pDYDnHYaQ</videoflash> <videoflash>BGTcKDJwXSc</videoflash>
Ora passiamo alla lista delle parti necessarie alla realizzazione
Le parti si dividono in quelle stampabili o realizzabili con una cnc
Parti da Stampare
Quantity Description Type Comments Diagram
3 endstop-holder RP
12 pla-bushing RP-PLA check your build file, the file makes either 4 or 12 Pm-bushings.jpg
le potete scaricare liberamente qui[1] in formato STL
Parti da Comprare
Non-Printed Parts ("vitamins")
Required
Quantità Descrizione Type Commenti
83 M8 dadi Fastener Buy a 100-pack to be on the safe side.
93 M8 rondelle Fastener Buy a 100-pack to be on the safe side.
6 M8×30 mudguard / fender washers Fastener
2 M4×20 bolt Fastener
2 M4 nut Fastener
2 M4 washer Fastener
22 M3×10 bolt Fastener
16 M3×25 bolt Fastener
4 M3×40 bolt Fastener
70 M3 washer Fastener
40 M3 nut Fastener 8 optionally locknut / stop nut / nyloc
2 M3 grub screw / set screw Fastener
3 608 roller skate / inline skate / skateboard bearing Bearings
4 ballpoint pen springs Spring
6 M8×370mm Threaded rod 3 per side
4 M8×294mm Threaded rod front / rear
3 M8×440mm Threaded rod top / bottom
2 M8×210mm Threaded rod Z-leadscrew
1 M8×50mm Threaded rod or bolt for X idler
2 8mm×495mm Smooth rod X-bar
2 8mm×406mm Smooth rod Y-bar
2 8mm×350mm Smooth rod Z-bar
1 225mm×225mm print top plate Thick Sheet
1 140mm×225mm print bottom plate Thick Sheet
1 840mm×5mm T5 pitch timing belt Belt
1 1380mm×5mm T5 pitch timing belt Belt
5 NEMA 17 bipolar stepper motor Stepper
50 small cable binder / ziptie Misc
1 Wade's Geared Extruder or any other compatible extruder
1 Electronics + endstops this can be RAMPS, Pololu Electronics, Gen6, Gen3, or anything else compatible
Le parti invece che necessariamente dovete comprare- la cui lista ho tradotto in italiano-le trovate sul mio blog [qui] segnalo inoltre questo sito per una presentazione sul montaggio: http://forums.bit-tech.net/showthread.php?t=191747 ricordo inoltre che per il montaggio sono presenti su questo sito video in inglese-vedere sezione build prusa-
MONTAGGIO:
La rep rap prusa è composta da due "triangoli equilateri che costituiscono le basi di appoggio laterali, è per ciò necessario realizzarne due le instuzioni prevedono l'utilizzo di fram vertex senza piede
Montare il triangolo-l'operazione va svolta due volte in quanto si necessitano di 2 trinagoli-
Parti necessarie
  • 3 RP frame vertex (non-footed)
  • 1 RP bar clamp
  • 3 x 370mm barra filettata da 8 mm
  • 14 dadi da 8 mm
  • 14 rondelle normali da 8 mm
Video Istruzioni:
<videoflash>3AKHa6Qx2MI</videoflash>
immagine realizzazione
Montare le barre frontali porta motore Y
Parti necessarie
  • i 2 triangoli assemblati
  • 2 RP bar clamps
  • 1 RP y motor bracket
  • 18 dadi da 8mm
  • 20 rondelle normali da 8mm
  • 2 rondelle maggiorate da 8mm
  • 1 608 cuscinetto a sfera
  • 2 barre filettate da 294mm
Video istruzioni <videoflash>fUohtLHwAOM</videoflash>
per un montaggio visivo seguite queste due immagini
Montare le ultime barre frontali
Le due barre sono utilizzate per collegare i due frame vertex dei triangoli
Parti Necessarie
  • 2 trinagoli precedentemente assemblati
  • 2 RP bar clamps
  • 14 dadi da 8mm
  • 14 rondelle da 8 mm
  • 1 cuscinetto a sfera 608
Video Istruzioni <videoflash>evUcBIiyCS4</videoflash>
Per un montaggio visivo:
collegamento con i frame vertex:
Montaggio vertice dell'asse Z
In questa fase si collegano i vertici del triangolo e si montano i supporti per l'asse Z
Parti Richieste
  • 2 triangoli precedentemente assemblati
  • 2 RP z motor mounts
  • 12 dadi da 8mm
  • 16 rondelle da 8mm
  • 2 barre filettate da 440mm
Video Istruzioni <videoflash>0FjQgkjNQ5I</videoflash>
per il montaggio visivo si seguano queste immagini
1
2
alla fine tutto dovrebbe essere come in questa immagine:
Assemblare il supporto dell'asse Z part 1
in questa parte si monterà il supporto su cui andranno le barre lisce che su cui si muoverà l'asse Z
Parte Richieste
  • 2 RP bar clamps
  • 4 dadi da 8mm
  • 4 rondelle da 8mm
  • 1 barra filettata da 440
Video Istruzioni <videoflash>bx8OCjpwhfo</videoflash>
per un montaggio visivo si segua l'immagine seguente
Assemblare l'asse Y part 1
in questa parte si montano le assi su cui si muoverà l'asse y e si alloggerà il piano su cui poggerà il letto
Parti Richieste
  • 4 PLA bushings
  • 1 225x140mm supporto letto in legno
  • 2 barre filettate da 406mm
  • 1 NEMA 17 stepper motor-o stepper qualsiasi
  • 1 driver per motore per muovere la cinghia-lo potete anche trovare in formato stl nell'elenco in cima-
Video istruzioni <videoflash>8Fy3XJ6t8bo</videoflash>
per un montaggio visivo seguire queste immagini:
in questa si vedono le proporzioni e le distanze richieste sul piano:
in questa si vede il piano di legno assemblato:
Assemblare l'asse Y part 2
  • 2 belt clamps
  • 1 cinghia da 840mmx5mm
  • 4 viti mm 3
video istruzioni <videoflash>flwv1vnk7Z4</videoflash>
