RUG/Pennsylvania/State College/Printers/PSU Wallace
Revision as of 21:20, 8 April 2014 by Tav5057 (talk | contribs)
Wallace
Color: White
Extruder: ?
Temperature: ?
3D printer codename: Wallace is a unit that is currently in progress. Construction began during the 2nd week of the Spring semester (January 2014). The effort is headed by Brandon Tunkel. The design is a modification of the RepRap Wallace printer, dubbed the 3DM1. The build is slated to reach completion by the end of the Spring semester.
The decision to switch to the Wallace design was based on several advantages over the Open Hybrid Mendel printers. First off, this style of printer is intended to be as simple as possible. This is accomplished by utilizing as few parts as necessary. This results in a lower cost and assembly effort. Additionally, it allows for a more robust printer. Fewer joints and points of attachment result in fewer places for unwanted motion or "play". Secondly, the Wallace design allows for a large print volume. The nature of the design permits a large range of motion in each axial direction. The printer bed is considerably large at 20" x 14.625", and the Z-axis can accommodate a print approximately 11" in height.
Other improvements with this printer that are not exclusive to the 3DM1 design are the bowden extruder and linear bearings. This extruder type allows for less weight on the
Log
Date Modification / Problem
4/08/2014 Mechanical components are assembled and nearly ready for function. Electronic components are in hand, but have not been attache to the printer. All wiring has yet to be completed. The Bowden extruder is assembled but still needs a hot tip and wiring.
4/10/2014 Progress will be made on Thursday.
Operating Specifications
Design Ohm
Electronics RAMBO 1.4
Firmware Marlin
Extruder 0.35mm
Heated Bed Yes, 55C
PSU Unit White - Current Condition
Assorted Prints
Video
<videoflash type="youtube">NUG-33G0zaU?hd=1</videoflash>
Operators
This machine was assembled by:
State College RepRap Users Group
S.C.R.U.G. Main · The Make Space · Intercollegiate Future Society · Wiki Help
